best palce to buy Cleveland wheels and brakes (kit 199-46)
Posted: Tue Nov 12, 2013 2:11 am
by ccondit
Can anyone recommend the best place to buy Cleveland wheels and brakes (kit 199-46)? Cheif, Aircraft Spruce ????
Re: best palce to buy Cleveland wheels and brakes (kit 199-
Posted: Tue Nov 12, 2013 2:40 am
Shop for the best price, both those places are good. (Spruce is a supporter of our association, however, having donated to our conventions.)
Posted: Tue Nov 12, 2013 6:17 am
by blueldr
Why not save money and go to a junker and buy the necessary serviceable parts. Save a lot of money, buy whiskey!
Posted: Tue Nov 12, 2013 12:50 pm
by fishdoc
Got mine from Wentworth. Took some cleaning up, repacking the wheel bearings and painting on the calipers but otherwise good to go.
About $600 less than the cost of new ones.
Posted: Wed Nov 13, 2013 3:36 am
The problem with buying brakes from a junk-yard for the purpose of conversion is.... no paperwork which is assigned to your airframe. In order to convert an airframe there must be a basis of approval such as STC, which will not ordinarily transfer from one airframe to another without the conversion-kit-mfr's approval.
This is an entirely different issue than the likelihood of buying junk parts with hidden damage (such as the common internal corrosion of caliper pistons found in junk-yard salvage jobs.)
Then there is the matter of obtaining the exact parts which meet approved conversions. Yes...it's possible to gather the salvaged parts together that will work... But are the parts you gathered the exact part-numbers used in approved conversions? ...and will your annual inspector find your source and method airworthy?
Sometimes the least expensive conversion is not the cheapest one. :wink:
Posted: Wed Nov 13, 2013 8:26 pm
by blueldr
I just knew that the paperwork advocates would panic at the thought of no STC for a set of cleveland wheels and brakes from the junkyards. In all the years that I had a C-170, I don't believe anyone EVER even looked to see what kind of wheels and brakes I had until I installed the double puck type calipers. They were Clevelands and they were on the plane when I got it and there was no paperwork. I guess I'm just lucky.
In my memory, over the years I seemed to have seen VERY few C-170 airplanes with other than Clevelands. I even changed a few out without paperwork, but they were early C-172s.
Posted: Wed Nov 13, 2013 11:42 pm
One of our members found that he couldn't transfer his airplane to another because it had McCauley brakes on it..... when he thought all those years he had Clevelands. His paperwork showed he had Clevelands.
To complete the sale, guess what he had to do?
(Good thing he never experienced a runway departure or ground-loop, heh?)
Posted: Thu Nov 14, 2013 4:46 am
by blueldr
Who was it that squashed the aircraft transfer over the brakes?
Posted: Thu Nov 14, 2013 2:15 pm
The pre-buy inspector had squawked the brake linings as worn-out... and while attempting to order replacements recognized that common 166-104 Cleveland/Rapco linings didn't fit, due to the fact his brakes were actually discontinued models of McCauley. (The correct linings were available...but the situation revealed the difference between what was logged as installed versus what was actually installed.)
(For those not familiar... McCauley mfr'd disc/caliper style brakes almost identical to Parker-Hannifin/Cleveland. McCauley also eventually became a Cessna-subsidiary. Thru the mid-60s and 70s Cessna installed ...you guessed it...McCauley brakes on 100-series airplanes.
Since many of those airplanes ended up in salvage yards, their parts are often purchased and installed on operational airplanes. This usually works out just fine as long as the purchaser knows what they are getting.
This odd matter occurred because at one time the old Goodyear brakes were being replaced with what looked like Cleveland brakes. A Form 337 was completed based upon another aircrafts' conversion using Clevelands. Unfortunately, the actual brakes being installed only resembled Clevelands...they were actually and old set of obsolete McCauleys supplied from a junkyard. The pre-buy inspector caught the error and suggested submitting for a new field approval but seller balked at the lengthened process and buyer balked at buying an airplane with an obsolete brake system. New Clevelands were installed (which came with the benefit of an included approval basis ...STC... and the two split the cost.)
delete
Posted: Thu Nov 14, 2013 7:10 pm
by bigrenna
delete
Posted: Thu Jan 16, 2014 3:22 pm
by flat country pilot
I currently have Bodell brakes and wheels. Parts are difficult to find. Therefore I may just switch to clevelands.
Does any one have good pictures of Cleveland double pucks installed? Both with the wheel on and off?
When I put the skis on, I take the Bodell brakes off. Can I leave the Clevelands on with straight skis?
Bill
Posted: Thu Jan 16, 2014 4:25 pm
by blueldr
I would guess that you could leave them on if you had some sort of a "keeper" in the caliper to keep from blowing the pucks out.
Posted: Thu Jan 16, 2014 6:15 pm
by johneeb
blueldr wrote:I would guess that you could leave them on if you had some sort of a "keeper" in the caliper to keep from blowing the pucks out.
and some way of keeping the caliper from sliding out as the rotor is want keeps the caliper in place.
Posted: Thu Jan 16, 2014 6:30 pm
by marathonrunner
I recall an AD from the 70's for McCauley wheels and a recurring inspection until some corrective action was done. I don't think it was for 170 series aircraft but if you do have that part number wheel assembly it would bear looking into. I also think there was a bulletin or AD for cracks for them. Have not seen McCauleys in a long time as most people opt for Clevelands
delete
Posted: Fri Jan 17, 2014 1:10 am
by bigrenna
delete
