Asking a question I should already know the answer..
Posted: Fri May 16, 2014 3:05 am
by wingnut
What is the distance between the main wheels, center of tire to center of tire, with wings off and engine/prop on?
In other words, if I lifted a 170B without the wings on it and sat it back down, what would the approx distance be center to center? I'm fabricating some fixtures/attachments for hauling a 170 on a different trailer and don't have my old one for reference. If someone has a 170 sitting around in a hangar, without wings installed but with engine/prop I would be very appreciative of a measurement. Or if you hauled one and recall the measurement that would be great too.
Del
Re: Asking a question I should already know the answer..
Posted: Fri May 16, 2014 3:30 am
by minton
Using a come a long U can make it whatever you want! :lol:
Posted: Fri May 16, 2014 2:59 pm
by wingnut
Lots of stress on the gearbox
Posted: Fri May 16, 2014 3:29 pm
by hilltop170
Hi Del-
I can only help with ideas but if you know what wings weigh, you could pick up a whole airplane using a scale and let it down and retain the weight of the wings on the scale and you would get real close.
Or, if you pick up a complete airplane and set it back down on rough pavement where the tires would not slide sideways, that would probably be close as well.
One other thought, if you pick up a complete plane and run a ratchet strap between the gear legs in their relaxed position and just pull the strap snug, it should not hurt anything when the weight of the plane is set back down on the gear. The strap would be carrying the load.
I know you have already thought about these ideas but in case you haven't, I hope one helps.
Posted: Fri May 16, 2014 11:02 pm
by wingnut
Hi Richard,
Those are all good ideas, and if there was a 170 on the field right now I might consider doing that. I can modify my fixtures on site. Just thought if someone already knew the measurement I could make it easy on myself :wink:
Posted: Fri May 16, 2014 11:48 pm
by minton
I've pulled them in 4 inches with no damage/wings off
Posted: Sat May 17, 2014 12:17 am
by wingnut
minton wrote:I've pulled them in 4 inches with no damage/wings off
Well then that would fit perfect with my setup. I can't have one rig that's perfect for all the aircraft we haul, so I've tried to build the most universal rig I could. I've made different fixtures over the years for all sorts of aircraft and was wanting to make some for a job coming up. I've used ratchet straps to hold gear from springing back outboard from one another after lifting, but never pulled them toward one another closer than their relaxed static position with zero weight (except just enought to keep the strap tight) That is the dimension I was looking for.
Posted: Sat May 17, 2014 12:24 am
by n2582d
94" between outside of wheelpant style axle nuts, early style gear, no engine, no wings, measured after lifting fuselage so gear was moved inboard as much as possible. Subtract about an inch to get measurement between outboard edges of 6.00 X 6 tires.
Posted: Sat May 17, 2014 2:30 pm
by wingnut
I remember seeing and old post discussing how someone hauled a 170 inside a box trailer. There was a picture of it still in the trailer. Thought that post might have some info but I can't find it.
No matter, I've enough fixtures to haul it upside down if I want. Thanks for everyone's input/advise. I've had one email and 2 phone calls from people who measured center-center in their hangar, wings/engine on. All 3 measured 90". I think spec is 86". I was hoping they would relax inward to 82-84" to fit between my wing cradles
Posted: Sat May 17, 2014 5:06 pm
by cfzxo
Del: Was it not discussed somewhere about bolting the axels on the inside of the gear leg with smaller tires? I have never tried it but it might work. That would make it very narrow .
Bill
Posted: Sun May 18, 2014 6:11 pm
cfzxo wrote:Del: Was it not discussed somewhere about bolting the axels on the inside of the gear leg with smaller tires? I have never tried it but it might work. That would make it very narrow .
Bill
Now THAT is thinking OUTSIDE of the box! I love it!
Posted: Mon May 19, 2014 3:13 am
by wingnut
Bill
Hi Bill, yes I think I recall that being discussed. It does work on some aircraft, but I think I've already determined it will not work on a 170 without fabricating an extension to move the axle either downward or inboard, or both. Not enough clearance between tire and spring.
Overall width is not a problem. My problem is interference with my wing cradles. I tried to link pics from photobucket last night but it said my pics can't be over 800 pixels high.
I think I have a solution and will know tomorrow. Thanks for the suggestions
Posted: Mon May 19, 2014 12:08 pm
FYI Del, you can't actually place pictures here at the forum over 800 pixels, but you can just put the link to the picture in the post and people can click the link to go see the pictures. Of course those pictures would have to be in an area the public could access, not in a password protected area.
Posted: Mon May 19, 2014 10:33 pm
by 4583C
I don't remember the measurements but it worked and " the Eternal Project" is on it's way to Mena. Thanks to Del and Bret.They started about 7 this morning and left about 2:30. They pulled the gear in about 4" but that kicked the top of the wheels out enough to interfere with the wing racks. The solution was some extra padding in the bottom of the wing cradles.
Posted: Tue May 20, 2014 3:25 am
by wingnut
Bruce Fenstermacher wrote:FYI Del, you can't actually place pictures here at the forum over 800 pixels, but you can just put the link to the picture in the post and people can click the link to go see the pictures. Of course those pictures would have to be in an area the public could access, not in a password protected area.
I'll see if I can figure out how to separate these pictures out from the skunkworks library and post the links. Too tired tonight. Paul worked us like rented mules. He did feed us mighty good though. Thanks Paul!!
