Torque value for exhaust gasket studs
Posted: Wed May 28, 2014 5:00 pm
by johnsunday
Anybody have the recommended torque for the exhaust header pipe nuts?
Thanks!
N2786C
Ratty ole Alaska Bushplane
Re: Torque value for exhaust gasket studs
Posted: Thu May 29, 2014 1:38 am
by KS170A
Aryana wrote:Continental SB96-7C (Torque Limits) says that the .25-28 Nut-Exhaust manifold flange with a Spirotallic gasket requires 100-110 in/lb or 8.3-9.2 ft lb. Validate this figure yourself before you decide to use it.
I always wondered if this applied to the brass nuts on the O-300 exhaust, or more to the larger engines. After a long day with little rest, my mind is thinking the O-300 had larger studs than .25", but I could certainly be wrong...
Posted: Thu May 29, 2014 1:57 am
by johnsunday
THANKS MUCH ARYANA!
Posted: Tue Jul 01, 2014 10:49 pm
by ragsrettzo
don't confuse the size of the wrench used with the size of the stud a .25 stud takes a 7/16
rags 9100A
