Question about Tail wheel assembly
Posted: Sat Jul 12, 2014 11:53 pm
by pilotjkl
I'm doing an annual inspection on my 170A, I disassembled the tail wheel bracket to replaced the U bolt and the channel 0510000-31 and after reassembly the steering chains are to long, what did I do wrong?
Re: Question about Tail wheel assembly
Posted: Sun Jul 13, 2014 1:02 am
Look at your leafspring stack. You've allowed it to shift forward and is no longer properly held by the bolt at the forward end of the leafsprings.
Posted: Sun Jul 13, 2014 11:39 am
Is this a test?
Notice how bolt 2 goes through top plate 8 inside bushing 5 then through the mount in part 1. It sets and holds the springs relative to the mount. You couldn't have this bolt installed correctly. And while your at it you also don't have the six bolts (19) and nuts installed holding the top plate on. But I'll assume this picture is take of a ruff fit assembly.
Posted: Sun Jul 13, 2014 12:27 pm
by sfarringer
The picture where the chains are slack may very well be the correct spring location.
The picture where the chains are tight looks like the spring is way too far back.
(I think it is a test, too.)
Posted: Sun Jul 13, 2014 1:05 pm
by wingnut
You have it installed correctly now. Lucky you found the problem before you damaged a plane
Posted: Sun Jul 13, 2014 2:31 pm
by bagarre
Also, make sure you install part number 16 in Bruce's diagram. I think it's called a chain guard. Search the forum for "Bent Steering Arm" to see why it's an important item.
Posted: Sun Jul 13, 2014 2:57 pm
sfarringer wrote:The picture where the chains are slack may very well be the correct spring location.
You are correct. I assumed the picture with the chains taunt was that of proper parts properly assembled. If it was not, that might explain why when proper parts are assembled properly, the chains adjusted for the former improper install would be to long.
Posted: Wed Jul 16, 2014 2:50 pm
by hilltop170
When I took my 170 to Del Lehman for restoration, he found my tailwheel with the same condition. The leaf springs were just butting up against the retainer bolt and the only thing holding the whole assembly in place was the tailwheel coil springs and chains. We had flown the plane from Alaska to Texas and around Texas for several months. Talk about lucky!
Posted: Thu Jul 17, 2014 1:47 am
by MoonlightVFR
Where is the source document for Bruce picture.?
I have a Cessna Service Manual 100 Series 1962 and prior . Not real helpful for C170.
Regards
Posted: Thu Jul 17, 2014 3:17 pm
by Romeo Tango
George/Bruce - do I recall correctly there was more information in a forum here about the bracket kit SK70A52-4? And/or a discount for club members? Annual this year found me need to make the replacement.
Posted: Thu Jul 17, 2014 3:48 pm
by DaveF
MoonlightVFR wrote:Where is the source document for Bruce picture.?
The 170B parts catalog
Posted: Thu Jul 17, 2014 5:59 pm
Romeo Tango wrote:George/Bruce - do I recall correctly there was more information in a forum here about the bracket kit SK70A52-4? And/or a discount for club members? Annual this year found me need to make the replacement.
That is correct. The Assoc'n has all the necessary documentation and a nice discount for the entire kit for it's Members. Join up!
Posted: Sat Jul 19, 2014 6:54 pm
by pilotjkl
wingnut wrote:You have it installed correctly now. Lucky you found the problem before you damaged a plane
Thanks everyone for all the help! This makes the most sense that it was not installed right previously, just glad it's right now
So much good help in this group, thanks again
