Rivets for Control Yokes
Posted: Mon Aug 04, 2014 3:52 pm
by Penneyh
Question for the group: We are in the middle of rebuilding stock Cessna 170 control wheels and have had the tubes re-chromed and the yokes powder coated. As part of this process, we had to drill out the original rivets connecting the yokes to the tubes. Does anyone have a source for replacement rivets? They are solid through most of the rivet and then hollow at the end to allow flaring. Thanks!
Heather
Re: Rivets for Control Yokes
Posted: Mon Aug 04, 2014 4:22 pm
by mike roe
If I remember correctly the correct lengths are expensive. I ordered longer from Preferred Air Parts NOS and cut them down. Measure the hole in the end and duplicate it after cutting to proper length. I have the proper dies for setting if you need them.
Mike Roe
Posted: Mon Aug 04, 2014 6:08 pm
Use MS screws and nylock nuts.
Posted: Tue Aug 05, 2014 3:28 pm
by Penneyh
Mike—thanks so much. The sourcing information was exactly what we needed. Do the dies function as part of the process of flaring the rivet end?
Posted: Wed Aug 06, 2014 1:06 am
by mike roe
Exactly, they roll the end over. If you want to borrow them let me know thru a pm with shipping address. I will get them out to you. I would suggest at least ordering one extra rivet.
Mike Roe
Posted: Wed Aug 06, 2014 3:36 pm
by Poncho73
gahorn wrote:Use MS screws and nylock nuts.
X2
Posted: Thu Aug 07, 2014 1:58 am
by n2582d
I believe the problem with using MS screws is that they will be a loose fit without an additional sleeve. A -3 screw has a dia. of .1895". The original rivet has a dia. of .219" See
this discussion on the 120-140 website.
Posted: Fri Aug 08, 2014 5:00 pm
by robw56
n2582d wrote:I believe the problem with using MS screws is that they will be a loose fit without an additional sleeve. A -3 screw has a dia. of .1895". The original rivet has a dia. of .219" See
You can drill it out and use a -4 screw or bolt.
