cowlings
Posted: Fri Sep 19, 2003 5:25 am
by n3439d
I am in need of a new cowling for my 55 170b. I have not found anything good at the salvage yards. So, will an older model cowling work with my engine baffles or would I need to change them too.
ken
Posted: Fri Sep 19, 2003 12:54 pm
by zero.one.victor
The 1948-1952 cowling uses an airbox-style baffling,they went to the pressure-cowl type baffling in 1953. You might be able to use an early 172 cowl. Is your entire cowl need replacement,or just the top or bottom half?
Posted: Sat Sep 20, 2003 11:45 pm
by Dave Clark
A lot of planes have changed from the early to the later baffle arrangement using the early cowls. It works just fine. I sure like the large openings in the top of the early cowls.
Posted: Sun Sep 21, 2003 3:36 am
by n3439d
thank you for the info, being able to use the other cowling opens up a bigger pool of parts at the salvage yards.
ken
Posted: Mon Sep 22, 2003 5:54 pm
by funseventy
Also you can look at straight tail 172 cowlings.
