Flap Roller Larceny?
56d
Post by 56d »
I just got a bill for replacement of the flap rollers on my '56 170. Ten hours labor @$50 and $274 for the kit (this after I pointed out to them before they ordered that even WagAero had them for $186. Should I swallow and write a check or call the police?
wa4jr
Post by wa4jr »
I'm not an expert on flap roller replacement...but 10 hours of labor? I would think that 5 hours would be plenty of time. I think some FBOs are set in their ways and use only one or two suppliers regardless of price...and pass it on to you. Maybe time for you to look for another shop...or else purchase the parts yourself for the job and then hand them over to the shop...and then sit off a few hundred feet and gaze in the hangar with field glasses to see just what they do with those 10 hours :twisted:
lowNslow
Post by lowNslow »
$274 is about the price of the McFarland STCed flap roller kit, however they state in their documentation that the job should take 4 hours. After looking at (but not yet doing) the job, that sounds like more than enough time.
Doug Echelberger
Flap Roller
Post by Doug Echelberger »
I just purchased the large area washers to comply with the service bulletin. I think they were about $2.75 each totaling about $20. My rollers were just fine. It took me about an hour to change both sides.
N2426D
North Calif.
buchanan
Flap Rollers
Post by buchanan »
I just put the larger washers along with the next size larger bolts on my B. The bolts and washers were $28. I rempoved the rollers and cleaned them up with solvent and re-lubed them. Total time no more than two hours.
Buck Buchanan, Valier, MT
C170BDan
Flap rollers
Post by C170BDan »
I have missplaced my copy of the service bulletin. If someone has it handy can you give me a quick rundown? Where have most of you purchased the kit from?
Dan
1956 170B N3467D
