Wheel Pant Hardware/Parts Sources
Hello,
I tried searching the 22 pages of previous forums on this topic. I didn't see exactly what I was looking for. If I overlooked a thread I apologize. Novice question here, I was unable to find the bolts that would attach the pants onto the backing plate and the axle. The Cessna manual isn't very descriptive. As for my question, how do I go about getting the hardware? Can I simply go to the hardware store or do I need to order the specific hardware? The book calls for five PK76XZ-10-6 screws and one AN6-5A bolt, and one AN936B616 washer, per side. I was able to locate the bolt on aircraft spruce, but nothing else and bolt has a "A" designation that aircraft spruce didn't specify. I'm not sure what the "A" stands for or if it matters. I'm fairly unfamiliar with part houses for aircraft and direction would be very much appreciated. Also whats the consensuses or best practice to air the tire up, with the pants on?
Thanks in Advance!!
-Jason
Thanks in Advance!!
-Jason
Jason P
53 170
SN 25878
![Image](http://imageprocessor.websimages.com/width/131/crop/0,45,131x50/southwestmissouripilotsassociation.webs.com/LogoColorTextBelow.jpeg)
53 170
SN 25878
Re: Wheel Pant Hardware/Parts Sources
Any AN6-5 will he fine.
For the rest, mine are AN3 and pretty sure -6
The "A" merely indicates that the bolt is not drilled for a cotter pin. (Think of it as indicating the hole is "A"bsent.)
The PK76XZ-10-6 is a sheet metal screw, No 10 in diameter (about 3/16") and 3/4" long. It may be what Cessna used back in the 1950's for this purpose and is why that is what is listed.
But if you have wheelpants mfr'd in the 1990's they probably have nutplates for machine screws, and you will attach the pants to the backing plate using #10 machine screws. (These are used when nut-plates are installed on your backing/mounting plate. It's also possible to use short AN3 bolts...but they aren't as pretty.
If you have tinnerman plates for sheet metal screws you'd use PK screws (this is what a PK76XZ-10-6 looks like) which have coarse threads.) These are available from Spruce. I recommend stainless screws but be aware that stainless screws have soft slots and are easy to strip with a poor-fitting screwdriver or if you use an electric driver you can rip the slots out of the heads.
If you were to order from Spruce their PN 04-01100 airplane screw kit for a C-172....it costs less than $35 and contains 410 assort'd screws.... then you would have all the machine screws you'd need for this job plus many many more which you will find convenient for other tasks. (Caution: These screw kits are not "structural" screws and should not be used in place of AN, NAS, or other structural hardware. But they are fine for fairings, covers, wheel pants, cowlings, etc etc.)
You should also order PN 04-00217 and PN 04-00218 by the hundred each (they cost .02 ea), ... they are nylon washers to slip beneath the heads of those screws and will help hold down corrosion. Use them wherever a stainless trim screw is placed, such as for holding down covers and cowlings.
Here's a short primer on aircraft hardware: http://www.zenithair.com/kit-data/ra/hardware.html
And...if you REALLY want to peruse and learn about it... here's a free Aircraft Hardware Catalog that you can have:
http://www.askbob.aero/sites/default/fi ... atalog.pdf
![Wink :wink:](./images/smilies/icon_wink.gif)
I've only ever seen the nutplate ones. +1 new something learned.
Stainless machine screws would look nicer and probably easier to work with.
I was able to get them mounted, mine uses the sheet metal screws. After a couple hours in the pattern the right tire started rubbing on the mud guard. I fitted and refitted for about three hours trying to get more clearance in the one spot. I finally decided it would be better to try again later. I was only able to get about 1/8" in that particular spot.
Jason P
53 170
SN 25878
53 170
SN 25878
Pretty!
What brand/model tires?
Very nice!
See! With fatter tires you wouldn't have that mud guard clearance problem and the time you spend working on and worrying about it could be spent flying.
...and washing, wiping, and scraping dried mud off your airplane.blueldr wrote:See! With fatter tires you wouldn't have that mud guard clearance problem and the time you spend working on and worrying about it could be spent flying.
- Ryan Smith
+1gahorn wrote:...and washing, wiping, and scraping dried mud off your airplane.blueldr wrote:See! With fatter tires you wouldn't have that mud guard clearance problem and the time you spend working on and worrying about it could be spent flying.
56D doesn't have wheel pants now and is flown off of grass primarily because she's used for tailwheel endorsements by the current owner. Almost every time the airplane flies, I clean off the leading edges, windscreen, oil/grease on the belly, exhaust stains, and MUD underneath the wings and struts.
Bare tires suck.
You know Ryan, I wasn't sure till your last post but know I've confirmed it. Your families name is shows up in the history of owners of my plane. They probably owned it before the one you are so fond of.
So I'll expect you here sometime on Saturday to detail out 7A. After all I flew it a week or so ago and that mud on the wings isn't going to remove itself.![Laughing :lol:](./images/smilies/icon_lol.gif)
- Ryan Smith
LOLBruce Fenstermacher wrote:You know Ryan, I wasn't sure till your last post but know I've confirmed it. Your families name is shows up in the history of owners of my plane. They probably owned it before the one you are so fond of.
I'd be happy to wash the mud off of the old girl, but I'm positive that nobody in my family can lay claim to ownership of N7A. My grandfather did own a GREEN J3 back in 1958...I guess that's close enough, right?
Ryan Smith wrote:[... My grandfather did own a GREEN J3 back in 1958...I guess that's close enough, right?
Probably... They both cruise at about the same speed when they're green.
![Mr. Green :mrgreen:](./images/smilies/icon_mrgreen.gif)
Hey I own a GREEN J-3. You could wash both of them and pretend your grandfather owned them.Ryan Smith wrote:I'd be happy to wash the mud off of the old girl, but I'm positive that nobody in my family can lay claim to ownership of N7A. My grandfather did own a GREEN J3 back in 1958...I guess that's close enough, right?
