Cockpit Light Pollution (52 B model/piano key panel)
Posted: Mon Nov 30, 2015 3:16 am
Like most 170s, I'm sure, 56D is a day VFR airplane. 99% of the time that the airplane is out of the hangar, I'm either flying it, or I'm flying the owner around in it (or with her in it). Prospective tailwheel students have dried up, so the only time that the primary instructor gets in it is to do his night currency. Occasionally I'll have the airplane out after dark, but it's rare.
That said, the light pollution inside the airplane is terrible. The biggest culprit is the dimmer rheostat having become an on/off switch, but there is a lot of light that spills out from behind the false panel and shines on the windscreen. This doesn't bother me nearly as much as it does Dave, but it does make adjusting my eyes to the outside more difficult. It's been bothering Dave, so he asked the owner if we could do some things to combat the light pollution inside the cockpit, and she agreed.
First, I would like to know if this is a common issue with the piano key-style panel, and if it is, are there some missing parts that this airplane doesn't have? The ability to accurately photograph what I'm talking about is above my abilities behind a camera, but there is sufficient gap over and in front of the shock panel and the panel cover that light spills out over the top. Since the light needs to radiate from the bulb, simply fabricating some sort of shield would doubtfully be successful. My thought is to line the top of the shock panel with some 1/4" wide adhesive-backed foam rubber (similar to wing saddle tape for model airplanes) in an effort to create a flexible seal to block light from shining on the windscreen. Has anyone done similar? This is exacerbated by the lack of ability to dim the lights, but it was a problem for him even when we could crank the lights down.
The second area of interest are the bulbs that illuminate the four 2" gauges on the fixed panel (ammeter, clock, oil pressure/temperature)...they appear to be too long for the sockets into which they're inserted. There is probably 1/2" of exposed bulb that illuminates the floor underneath the panel. There is so much light that I thought that perhaps the missing post light on the far right-hand side of the panel had fallen down (more on that later), but examination showed that it was those smaller post lights. It appears as though the exposed portion had been painted/tinted red at some point...presumably this was to tone the light down. Are the lights supposed to be like this to create some ambient light in the cabin, or does it sound like we have the wrong bulbs installed? Whatever they are, they've been there a long time.
In that same vein, we're missing a post light on the far right-hand side. I thought perhaps the bulb had simply burned out, and pulled the panel cover to check the type to get a replacement and found that the socket itself was missing. Not wanting to dig too deep into it until it's time to turn wrenches, I am not sure how they're even installed - I presume that the wires for each socket are run individually to the dimmer rheostat? Are the sockets hard to come by? I haven't pulled the shock panel, but I'm going on pretty good guess that the entire socket is missing after looking under the panel, but it could very well be simply bundled with some wires and forgotten. Assuming the wiring is missing, what sort of bill of materials am I looking at to add the missing post light? It's the far right one, so it's only affecting the VSI and tach, but it's still a pain.
This is probably foolish, and is not related, but I would like to replace the piano switch grommets as the one for the master switch is completely missing (and creates a problem for people thinking that they've turned off the master when they really haven't). Since I may have to fiddle with the post lights for the fixed panel, I figure this would be an opportune time to address this as it's been bothering me for a long time.
The main qualifiers for this project are that it has to be simple and (relatively) inexpensive. I want to fix what's there, not replace an entire system when it's not necessary. While I'd really like to abandon the post light system altogether and change to electroluminescent bezels, today is not the day for that, nor will it be any time soon. Once I actually own the airplane, I would love to zero time the airframe, but for right now, we're enjoying what we have. I'm flying the airplane between 10-15 hours per month (and I'm knocking out a bunch of hood work and cross country time for far less than it would have cost me to do a dry lease on a friend's 150), and loving life.
Any input or suggestions are appreciated. I believe that there was a pretty lengthy thread about dimmer rheostats on here in the not-so-distant past, so I will refer to that for that portion of the repair, but I welcome input for the other topics/questions posed.
Best regards,
Ryan
Best regards,
Ryan
