Landing Gear Box: Where can i buy two and how to install
Posted: Fri Dec 04, 2015 2:19 pm
by oakesje
Hi Guys - instead of selling my damaged C170B I've finally decided to rebuild it...wish me luck - Vic Prefontaine has 70 years experience in metal working for Air Canada and Perimeter and has kindly volunteered to provide guideance, instruction, and help!!! He deserves a gold medal for patience :). The rudder and aileron fin is now repaired, all of the other parts are undamaged and hanging on the hangar wall. Now focusing on the fuselage - unrivetted the firewall - wow it looks better already, removed the crumpled forward floor panels and have started on the consol and floor panel that covers the gear boxes. Where do i go to buy two new gear boxes? Any tips on installing. I have contacted P-Ponk but they just have reinforcing parts not the whole gear box and I did an awesome job of crumpling both - especially the right gear box. Thank you for any and all advice/photos/sources on this....lookinig at it positively there are tons of panels that are still beautiful, a few that are crumpled pretty good. Am going to put an O360 Lycoming in, found the STC for the IO-360M1A,B engine does that have to be fuel injected ...not sure about the difference between A, B?
Jill
C-GGPI is coming back to life
Re: Landing Gear Box: Where can i buy two and how to install
Posted: Fri Dec 04, 2015 3:57 pm
by cessna170bdriver
I think you'd be lucky to find a NEW gear box, and I'd hate to guess what it would cost, but you should be able to find a salvaged one. Del Lehmann at Mountain Airframe in Mena, AR should be able to point you in the right direction.
http://cessna170.org/forums/viewtopic.php?f=24&t=4796
Posted: Fri Dec 04, 2015 4:51 pm
by c170b53
Jill, I hate to give away my known stores of resources but then again it's about the plane and you are a long standing member. Pls PM me your email, I know I have it at home but I'm on my way to an out of town Xmas party.
Posted: Fri Dec 04, 2015 10:49 pm
by ghostflyer
Firstly I haven't been eating yippee beans and no smoken Mary Jane , but have been told that a Cessna 206 gearbox will fit. Or slightly modified to,suit. So I,would be doing some research and running the tape over a Cessna 206 gearbox. However the source of this information is now deceased so I can't check out from him how he came to this conclusion .
Posted: Sat Dec 05, 2015 10:18 pm
by MoonlightVFR
Gearbox availability
36 years ago at the Ithaca Convention in NY. the gearbox was number one 1 on John. Benhams want list.
In detailed requests with Cessna plant they explained that they would have to create and let 14 different contracts with outside vendors.
Tell me more about the 206 gearbox. Isn't that a wide body?
Posted: Sun Dec 06, 2015 1:18 am
by ghostflyer
The source of my information regarding the gearboxes of the 170 and the 206 is deceased but will try and find his business partner who would have some information on this subject . However the gearbox of the early 180 ,s and the 170 should be similar also . I would be running the tape over both .
Posted: Sun Dec 06, 2015 2:43 am
by bagarre
We couldn't be so lucky that the early 172 gear box wasn't just a 170 gear box in a different location.
That would have been a wonderful thing.
Posted: Sun Dec 06, 2015 12:13 pm
Early 172s DID have the front gear box installed but not used. Don't know when Cessna stopped this practice.
Posted: Sun Dec 06, 2015 1:34 pm
by bagarre
Bruce Fenstermacher wrote:Early 172s DID have the front gear box installed but not used. Don't know when Cessna stopped this practice.
I heard that some of the early 172s were drilled for the box but didn't actually have it installed.
It'd be a worthwhile investigation to find out as gearboxes are tough to find.
Posted: Sun Dec 06, 2015 3:56 pm
by 48RagwingPilot
A similar rumor circulated with respect to early C182's. While the bulkheads were pilot drilled for the gear boxes, the boxes themselves were ever actually installed.
Posted: Sat Dec 12, 2015 4:30 am
by Arcticmayhem
You might call up Stoots Aviation in Fairbanks. He has been doing tailwheel conversions on 172/175s using new 180 gearbox, 180 gear legs, and P-ponk kits. He must have a source for the parts, perhaps you can convince him to share.
Posted: Sat Dec 12, 2015 5:40 pm
by blueldr
Maybe that hull down in Camarillo is going to be parted out.
See about it in the Trademart section.
Posted: Wed Dec 16, 2015 4:49 am
MoonlightVFR wrote:Gearbox availability
John D. finally found a NOS gearbox and bought it from a closing Cessna distributor. He sold it to Bill Goebel who installed it in N146YS during it's restoration.
John D. inspected the installation when we met at my first Texas fly-in arranged by Louise Bickford at Lockhart, TX. He told me he believed it to be the last NOS gearbox in existence.
Posted: Thu Dec 17, 2015 9:06 pm
by hilltop170
Here is another possibility for gearbox parts. I got this about a year ago but they may still have what you need.
Posted: Fri Dec 18, 2015 2:07 am
by oakesje
[quote="hilltop170"]Here is another possibility for gearbox parts. I got this about a year ago but they may still have what you need.
[/quot
thank you - just sent an email to Sutton Aircraft asking if they still have the gear box - sure appreciate the leads
J
