Ideas for Encoder Mounting
Posted: Tue May 24, 2016 3:41 am
by nippaero
I'm looking for some ideas on where to best mount an Ameri-King 350 encoder under the panel. Where/how is yours mounted? The previous owner had it mounted on the side of the panel near the pilots leg. I am replacing the side panels and don't want it there.
Re: Ideas for Encoder Mounting
Posted: Tue May 24, 2016 5:21 am
by DaveF
Mine (different type, but similar size) is attached to the firewall immediately forward of the transponder.
Posted: Tue May 24, 2016 9:32 am
by cessna170bdriver
I mounted my Narco encoder on top of the glove box.
Posted: Tue May 24, 2016 10:02 am
by lowNslow
cessna170bdriver wrote:I mounted my Narco encoder on top of the glove box.
Same here.
Posted: Tue May 24, 2016 1:22 pm
by 170C
Mine in on the left side of my glove box.
Posted: Tue May 24, 2016 3:24 pm
by nippaero
I just got through putting a glove box door back on my panel. Someone had removed it a long time ago and installed a radio/ADF in there. I need to build a new glovebox.
Not sure I want to poke any more holes in the firewall.
Posted: Tue May 24, 2016 4:39 pm
by nippaero
Aryana wrote:Mine is on the firewall
Is it just using a couple screws and some tinnermans?
Posted: Wed May 25, 2016 4:03 am
by 48RagwingPilot
Left side of glovebox. Solid mount, easy access.
Posted: Wed May 25, 2016 11:28 am
by jlwild
Radio shop, many years ago, installed mine on the back of glove box. When I asked why, they said easy access.
Posted: Wed May 25, 2016 2:27 pm
by DaveF
The problem with mounting the encoder to the glovebox is that you have to move it whenever you pull the glovebox. Seems I have to do that about once a year to install or inspect something up under the instrument panel. Not a huge deal, but I like to keep disassembly and reassembly as simple as possible.
Posted: Thu May 26, 2016 3:55 am
by cessna170bdriver
DaveF wrote:The problem with mounting the encoder to the glovebox is that you have to move it whenever you pull the glovebox. Seems I have to do that about once a year to install or inspect something up under the instrument panel. Not a huge deal, but I like to keep disassembly and reassembly as simple as possible.
I must be missing something on annual inspections. I don't think I've had my glovebox out more than twice in 34 years.
Posted: Thu May 26, 2016 12:09 pm
by edbooth
cessna170bdriver wrote:DaveF wrote:The problem with mounting the encoder to the glovebox is that you have to move it whenever you pull the glovebox. Seems I have to do that about once a year to install or inspect something up under the instrument panel. Not a huge deal, but I like to keep disassembly and reassembly as simple as possible.
Me too Miles. Only had mine out once in 46 years and that was to use it as a pattern to build another one.
Posted: Thu May 26, 2016 3:50 pm
by DaveF
Not annual, but I installed new radios, new RH side instruments, replaced the instrument suction hoses and vacuum regulator, and replaced the battery-to-ammeter wire. All of that is on the RH side, and on my '54, none of it is possible without removing the glovebox. And I did it in several sessions over several years, so each time I had to pull the glovebox.
My point is that the more you tie stuff together the more difficult you make maintenance and the less likely you are to do it. Or the more expensive it becomes.
Posted: Fri May 27, 2016 12:58 pm
by cessna170bdriver
I just make it a point to minimize firewall penetrations. I almost came to blows with an AI years ago when he drilled a hole in my original condition firewall to relocate an instrument air filter that I had mounted on the back side of a radio stack support angle, a perfectly serviceable location. I might be talked into double-sided tape to mount an encoder to the firewall but I'd never drill holes in it for screws.
Posted: Fri May 27, 2016 1:13 pm
by nippaero
cessna170bdriver wrote:I might be talked into double-sided tape to mount an encoder to the firewall but I'd never drill holes in it for screws.
That's almost what I was thinking. The thing only weighs a few ounces and could be secured with some industrial strength Velcro to the side of the fuselage or firewall. The kind with the little plastic fingers. It is almost impossible to pull apart once you stick it together.
