Spinning Primer Knob
Posted: Sun Aug 07, 2016 6:59 pm
by nippaero
I have a problem with the knob on my primer spinning. It makes it difficult to lock/unlock the primer. Is there a fix for this? I cant figure out how the knob attaches unless it is pressed on.
Re: Spinning Primer Knob
Posted: Mon Aug 08, 2016 9:45 pm
by ghostflyer
I had a similar problem and the knob is threaded on and I used super glue to hold it on But after a about 18 months the knob cracked and fell apart. I tried buying one , nobody could supply a knob so a washer was soldered onto the shalf with a nut and the whole built up with heat shrink to protect against sharp edges. Works just great. I could have bought a completely new unit from Spruce for Mega bucks.
Posted: Tue Aug 09, 2016 11:16 am
Our original knob is long gone. Replacement knob is glued on with JB weld.
I'd use "Super Glue" (cyanoacrylate). You can find this at hobby shops in a thicker viscosity that cures in about 60 seconds which might fill the gaps and give you the time you need to properly place/thread the knob back on. A 5 minute epoxy would also work.
Posted: Tue Aug 09, 2016 3:03 pm
by nippaero
Maybe my threads are striped then. My know just turns in place. I can't pull it off.
Posted: Tue Aug 09, 2016 4:50 pm
If you can't pull it off then I'd use this "super glue" Let it wick between the knob and the shaft.
Posted: Tue Aug 09, 2016 7:07 pm
by nippaero
I'll give that a try. I have some CA.
Posted: Wed Aug 10, 2016 6:21 pm
Drill and "pin" it with a roll-pin.
Posted: Thu Aug 11, 2016 12:28 am
I would not drill and pin it. First you are likely to get an oversize hole in the knob as the plastic way melt. Second I think it likely the 70 year old plastic knob will likely split at the drilled holes.
Posted: Thu Aug 11, 2016 9:18 pm
Bruce Fenstermacher wrote:I would not drill and pin it. First you are likely to get an oversize hole in the knob as the plastic way melt. Second I think it likely the 70 year old plastic knob will likely split at the drilled holes.
I agree. My advice is not appropriate for a plastic knob. I had not recalled it was a plastic knob, I had to go back and look at the pic.
Posted: Tue Oct 18, 2016 10:45 pm
by nippaero
Just to close the loop on this. I ended up putting a couple drops of thin CA on it and letting it wick into the knob. SO far it has ben working great. No more loose knob. :)
