'52 prior cylinder baffle parts made
sfarringer
Re: '52 prior cylinder baffle parts made
Post by sfarringer »
Thanks, Bruce.
Mine will take a little more metal removal than that. But, it is probably because they are owner produced parts that were made to fit pretty tightly against Continental covers.
I ended up deciding to put the Continental rocker covers on for now. When I make the new set of baffle parts, I will make them to fit the new Millenium covers. Or maybe I should hire you to cut out a set!
Ragwing S/N 18073
My Mothers day gift to me. Finished a new set of inner pressure cowl doors to go with the new center section I made previous. Only have to install the seals. All made from .020 3003 H14 aluminum. Formed the edges around a MDF form block by hammering with a leather hammer.
MDF form block used to hammer out the side pieces
Right side
Right side
Left side
Left side
All this took enough hours that even the cheapo in me is thinking the Airforms price is not out of line.
But of course i have the satisfaction of knowing I made it myself.
9976AJds
Post by 9976AJds »
Do you have any "Texas" Baffles for sale? I would love to buy a 4 pac. just flat, I can cut and brake here. I am making rough items with tin snips, not the quality of yours. JD
What do you mean by "Texas" baffles?
Bruce Fenstermacher wrote:What do you mean by "Texas" baffles?
These perhaps? This is from the Bowers Flybaby website.
9976AJds
Post by 9976AJds »
Thanks President, you need to picture the State of Texas and compare to the shape of the 4 Between Cyl. Baffles.
I made my own cutting with tin snips and Saber Saw (narrow fine tooth blade). I am set for the next fifteen years at 110 flight hours per year. Enjoy the Annual Reunion, I'll be joining you-all in 2018 FL. works great for us. JD
9976AJds wrote:Thanks President, you need to picture the State of Texas and compare to the shape of the 4 Between Cyl. Baffles.
What's happening in 2018 FL..???
There was an announcement there would be a proposal made for the 2018 TIC170A convention to be held in Florida.
