Correct Ground Stance
- wa4jr
I know I have seen the procedure mentioned before, but I can't find it using the search feature. My 170 sits with the left wing low to the point where the ball is half out in the TC. What is the procedure for bringing the aircraft level on the ground via landing gear leg adjustments?
Yes, Dave you are on the right track. The "shims" are nothing more than ordinarly AN960 or AN960L flat washers, installed at the inner gear leg attach bolt, beneath the gear-leg inside end.
The specification Cessna used to level the airplane is to measure each wingtip to ground clearance. If within 3 inches of each other, they are correct and within spec. (Pretty generous spec., 'eh?)
Karl,
I was able to get a washer under my gear leg after I had installed my PPonks, It was a little tight, what i did was as I slid the gear leg in, I had put the gear bolt in far enough from the underside to hold the washer in place, once the gear was in position I removed the gear bolt from the bottom and then installed the bolt from the top.
Vic
N2609V
48 Ragwing
12N Aeroflex
Andover NJ
N2609V
48 Ragwing
12N Aeroflex
Andover NJ
Go to the Association home page. Click on links. Click on P Ponk. Click on landing gear. Click on beef-up kit. Then read all about it.N73087 wrote:can someone explain "PPonks"?
It is a mod to beef up the connection where the gear legs attach to the fuselage. Then,when you severely ground-loop your 170,instead of tearing the gear leg out of the gearbox,you will tear the gearbox out of the fuselage,along with the forward door post.
At least that's the opinion of some. It may or may not be true. By the time things reach that point,there's gonna be severe airframe damage no matter what.
A previous owner put the Ponk mod on my ragwing. Like the 180 gear legs,it isn't something that I would necesarily have done myself,but don't mind it too much either.
I'm trying to decide whether or not to go for the BAS pull handles that have been on my want list for about 5 years now. They're about $180 for the kit nowadays. I about got it rationalized as a late Christmas present for myself.
It's a beef-up kit to reduce the possibility of the airplane being wrecked because the single bolt/nut that holds INBOARD end of the gearleg let go or stripped. That single nut/bolt is under great stress in some ways and the threads can strip and allow the gear leg to fold under the fuselage. The damage is significant.N73087 wrote:can someone explain "PPonks"?
The P-ponk kit adds a machined forging to the gearbox that prevents the gearleg from complete collapse should that bolt/nut fail and/or prevents the failure by strengthening the gearbox/gearleg attachment. (The bolt no longer strips because it is assisted in holding the gearleg by the forging.)
Yes, if you wreck the airplane hard enough you can damage the airplane even more. Sort of like if you bump into the wall with your spinner you won't need a shoulder harness, but if you smack it at 100 knots the shoulder harness will not help and you'll now have to also replace the entire cabin of the airplane.
Pponk is the STC-holder's name spelled backwards. (Knopp)
http://www.pponk.com/HTML%20PAGES/gldr.html
You can see a picture of the p ponk I installed in my ragwing when I did the annual, sorry I don't have any pictures of while I was installing it but the camera battery went dead
on the day of installation. Took us four hours for installation of one gear then about 2 hours for the second. Good thing I don't charge myself alot of money.
Pponk pics http://www.sandhillaviation.com/170.html
Chao
Chao
Vic
N2609V
48 Ragwing
12N Aeroflex
Andover NJ
N2609V
48 Ragwing
12N Aeroflex
Andover NJ
