panel hole
panel hole
My instrument panel in the 170B has a hole about 3/4" in diameter
below the center instrument. Can somebody tell me what that
hole was originally for? Thanks!
Re: panel hole
Jim,
Your first post said that you had a 1950 170A. Did you trade that in for a newer 170B? I'm guessing what you are looking at is the hole for the knob on the horizontal directional gyro. See figure 76.
Re: panel hole
What year is your plane? There are differences in the panels by year. If it's slightly below a 3" instrument right in the center of the panel below the glare shield, it's probably the hole for the adjustment knob of an AN DG that was originally in the 3" hole above it. I still have the AN DG in my plane, and that's where the knob is (in a separate hole).
Edit: I see Gary beat me to it. We must have been posting at the same time.
Gene Feher
Argyle (1C3), NY
Argyle (1C3), NY
Re: panel hole
I've got a '50A and a '52B. Getting ready to sell the A. I think they both have that hole.
Apparently it was for an adjustment knob for the DG - thanks.
Re: panel hole
I have a 1958 C-180A with that same hole. Still have the AN DG that came out of it from the factory that still worked, although it sounded like a coffee grinder.
Re: panel hole
I've found a use for that empty hole. I'm going to fill it
with a picture of Lauren Graham, star of The Gilmore Girls.
Re: panel hole
Possibly a 1" dia vac gauge could be installed in the hole, or an iPad USB power source.
Re: panel hole
Or a button plug:
- Attachments
- ButtonPlugs.jpg (2.89 KiB) Viewed 15851 times
Re: panel hole
George- I remember you used to call them Wilkie buttons.
Re: panel hole
Yep...that's what the old timers called them and the term became synonymous. You've got a scary memory.hilltop170 wrote:George- I remember you used to call them Wilkie buttons.
- Ryan Smith
Re: panel hole
I never knew them by any other name! I used to tell my students that's what they were called, too.gahorn wrote:Yep...that's what the old timers called them and the term became synonymous. You've got a scary memory.hilltop170 wrote:George- I remember you used to call them Wilkie buttons.
