Method Put Air in Tire Scott 3200
Posted: Sat Sep 21, 2019 10:52 am
by MoonlightVFR
There has got to be a easy way to air up that tiny tailwheel. Scott 3200.
Please share your method with me.
Regular air hose tip just does not work smoothly. Tiny space , Fat old Fingers with Joint concerns.
Re: Method Put Air in Tire Scott 3200
Posted: Sat Sep 21, 2019 11:40 am
No easy way. First look to see what side the valve is on then get done on the ground once on that side with the hose and air chuck ready and in reach. Take the cap off. Stick finger in and push valve to a position the air chuck will fit on while pushing on the air chuck. With an air supply over 60lb it only takes a second or two of air to exceed 35lb in these small tires.
If you have an air chuck you find too big, and you are unable to get it on the stem, remove it from your hanger and get another. If it remains in your tool box, it will surely be the one you select every time you flop on the ground to do this. Same goes for the air gauge.
Posted: Sat Sep 21, 2019 2:22 pm
by c170b53
I used to use valve stem extensions until I forgot to remove it. Forgot, went to push the plane out and heard a swoosh sound, snapped the valve stem at its base.
Like Bruce said, find a long headed chuck that fits or make it fit by grinding down the sides of the chuck.
Posted: Sat Sep 21, 2019 2:34 pm
by daedaluscan
I use a valve extension. Makes it very easy. You do have to remember to remove it though:)
Posted: Sat Sep 21, 2019 5:59 pm
by pdb
Another vote for valve extenders. Buy the cheap black plastic ones at an auto parts place.They look like the ones below but they’re plastic. I keep several in the glove box of the plane and the car because I keep losing them or lending them out.
Proper tail wheel tire inflation is important for long tire life and proper operation.
Posted: Sat Sep 21, 2019 7:03 pm
by c170b53
Peter, like your graphic, I also carry slime and a spare tube...have had more than one flat little wheel and now you might say I’m paranoid
Posted: Sat Sep 21, 2019 11:58 pm
by daedaluscan
I keep a spare tail wheel and main tube and an old tail wheel tire in the plane.
Posted: Sun Sep 22, 2019 4:48 am
by wabuchanan
If you put it on, pump it up, and take the extender right off, you hopefully won't forget it. It's a quick and easy solution.
Posted: Sun Sep 22, 2019 7:30 am
by ghostflyer
I know of a aircraft with the same tail wheel setup we have on the 170,s but its a sky fox in the experimental category. What he has done is filled a old tail wheel tire with PRC 1422 but left a small channel in the center and filled it with a grey silastic . I have bounced it around while taxiing and it feels the same as if filled with air . I am not advocating doing this with our cessnas but I am watching with interest. The issue we have in this country we have a large thorn that grows on the ground and has 3 sides with 3 points. They go through tail wheel tires very easily. Plus the wind will blown them around also . And can make life miserable on a tarmac surface.
Posted: Mon Sep 23, 2019 2:09 pm
by n3833v
I use a modified 4" metal extension such as used on truck inner tires. Very easy to use and you do have to remember to remove before flight.
Posted: Mon Sep 23, 2019 2:59 pm
by edbooth
If you can find one of these straight air chucks, it works good.
Posted: Mon Sep 23, 2019 5:28 pm
by brian.olson
I personally carry this foot-operated pump in my maintenance box in the back of the plane, and I use it to put air in the mains and tailwheel whenever needed. The pressure gauge isn't accurate (I carry a shirt-pocket one for more precise measurements) but it's small and lightweight, it fits the tailwheel without any problem, and I can carry it with me.
https://www.harborfreight.com/air-foot- ... dEQAvD_BwE
Posted: Mon Sep 23, 2019 5:47 pm
by c170b53
Ed might have you gotten that from a WW II vet ?.
Posted: Tue Sep 24, 2019 2:27 pm
by edbooth
c170b53 wrote:If you can find one of these straight air chucks, it works good.
Jim, I can't remember where I got that thing from, have had it for a long time. Might have even been a WW I vet.
Posted: Tue Sep 24, 2019 4:04 pm
by counsellj
You can find the straight chucks on Amazon. Sorry, I don't have a link.
