'48 170 Right Wing Tanks
Posted: Mon Oct 28, 2019 11:18 pm
by MarcR
Does the outboard fuel tank on the right wing have a fuel drain that is plugged and not used? If so, have any of you lucky '48 owners installed a drain in the outboard tank? If the drain port is there and blocked off, one of my winter projects will be to install a drain.
Thank you in advance,
Marc Remhof
651-470-9647 or remhof@q.com
Re: '48 170 Right Wing Tanks
Posted: Tue Oct 29, 2019 12:02 am
by sfarringer
No fitting exists for a drain valve in the outboard tank (unless someone has welded one in after it left the factory).
But, the rear interconnect line is positioned pretty well for allowing water to drain to the inboard tank.
Posted: Tue Oct 29, 2019 2:20 am
by mit
Had a 48 for 10 years no need for another drain.
Posted: Tue Oct 29, 2019 7:50 pm
by MarcR
Thank you!
Marc
