Cowl Rub Strip Material
rschreiber
Post by rschreiber »
The rub strip material attached to my cowling that goes around the air filter is starting to disintegrate. I couldn't find the Cessna part, but I did find this:
http://www.brownaircraft.com/category-s/73.htm
The Cessna part in the IPC looks to be a similar part number to the rub strip used on all the other engine baffling.
What are you all using when this material needs to be replaced?
Thanks,
Ryan
Ryan
Re: Cowl Rub Strip Material
This is what I believe you want:
http://www.brownaircraft.com/product-p/ba-28-1.htm#
rschreiber
Thanks for the reply. I'm glad to see that's the solution. It will save me the cost of buying a 9-foot section of the other stuff!
Ryan
