What coax fitting is this?
dstates
Post by dstates »
I found a spot on my radio coax cable that is worn and while I have things apart I’ll run a new cable. Can any of you tell me what fitting part number I need to order? It is the fitting on the right in the picture with the arrow pointing at it. I don’t know if you need his info but the radio is a KX 170B and I plan on ordering RG-400 cable.
Is it a BNC male?
Thanks,
learaviator
Re: What coax fitting is this?
Post by learaviator »
Yes, that is a BNC male. 11-01802 is the Aircraft Spruce P/N.
"You can only tie the record for flying low"
1950 170A N9907A 180hp. STOL
dstates
Post by dstates »
THANKS!!
