Maintenance Induced Emotional Roller Coaster
Posted: Mon May 18, 2020 1:56 am
Two steps forward, one or two steps back. Am I the only one who thinks they are about done with a job just as a new issue pops up? It has been an Emotional Roller Coaster!!
I bought my 170A last June and new my first annual would be a big one. Plans included installing a new left aileron, fuel tank gauges and LED nav/strobe and landing lights with the addition of a new piano key switch and wires.
Plane came into the hangar on January 19th.
The new switch and wires turned into all new wiring behind the panel for all the switches and replaced fuses with circuit breakers... ok, just some scope creep. That is to be expected.. CB panels and new wiring went ok, just a lot of time.
Then, a rudder centering spring was discovered broken, not easy, but got it done.
Went to top off master cylinders and one of them wouldn’t build pressure. Ended up replacing lock-o-seal and piston o-ring twice and bled it multiple times to get it to work.
Found radio antenna coax had a spot that was worn through to the shielding so replaced coax. Then had radio squeal when transmitting. That eventually went away, but now when I press the push to talk switch my generator cuts out. I still need to figure that one out.
After running the engine for the first time since it was in the hangar we found a fuel leak at the selector valve. Apparently it is one of the 170 owner rights of passage. After installing and removing it three times it takes more time to drain the fuel than it takes me to remove and replace. Maybe I should hire out to other members...
Now that fuel valve is fixed, I was closing up the plane after testing the voltage regulator/radio issue, and found that the passenger door latch mousetrap spring is broken. Was fine yesterday.
What is left on the special 170 list that is going to get me once the latch is fixed? It’s May 17th now. Will I be flying by June?
Throw in the coronavirus and it has been a heck of a spring. On the positive side, because of all the shutdowns I’ve had more time to work on my 170, my A&P IA is great, I’m becoming very familiar with my plane and the list of possible things to replace has to be getting shorter....
Just had to vent a little. Doug
