New to me 170B
Posted: Mon Jun 22, 2020 1:00 am
by IP076
After an earlier deal fell through, It's looking very likely that I'll be taking ownership of a 1953 B model this week. I've got a list of 337s from an FAA records search. Seems to include a lot of popular mods. I've been googling each, but I thought I'd post here just to get some info from the experts.
Here's a list and what I've found so far:
Part Bartone Exhaust Extensions - most reviews have been favorable. Seems to keep the underside a little cleaner, sound is subjectively better, not quite sure if it's quieter or louder...feedback seems to go either way.
Skytronics Jasco 50a alternator - I guess a little more juice never hurts, as long as the little increase in weight doesn't bother you.
Rosen sun visors - no concerns here, liked having them in any other airplane I've flown with them.
Single piece windscreen - I suppose the only argument against is keeping an airplane original?
Hooker shoulder harnesses - good to have, might have chosen the BAS ones if I picked, but these seem fine to me.
George O Johnson Teflon Control Tube Balls - seem to be a better replacement than OEM, but I'll admit, didn't find much else in a search.
Whelen anti-collision lighting system - I'm a fan of being seen...so I'd say it's a good mod to have.
Aviation Development Corporation Externally Mounted Oil Filter (STC SA4172NM) and Engine Adapter (STC SA5743NM) - Seems ADC is no longer around, so sourcing any replacements might be an issue. I need to read up a little more on this one, but I'd be curious what other members experience is.
B&C Specialty Products Model BC 320-1 starter - other than getting rid of the pull cable, I'm not sure if there's further advantages/disadvantages
Mogas - Current owner has not been running mogas.
P.Ponk landing gear support brackets (STC SA4170NM) and castings (SA2918NM).
BAS tail pull handle kit - seems a no brainer for ease of moving the airplane in and out of the hangar
STOL Cuff from Stene Aviation - pros/cons debated here on the forum. For my expected use in WA/ID, it will probably come in handy
As for radios it has an old Narco 810 and a Garmin 325 Transponder. I'll likely add the tailBeacon from Uavionix for ADS-B compliance.
This is my first 170, and my first airplane. Looking forward to the adventure ahead. If anyone has any advice or info on the above mods, good or bad, I'd be all ears.
Any other must have accessories for the first time aircraft owner? I'd like to put together a little survival/safety kit. Maybe get a pack of tie down anchors and straps to use while camping elsewhere.
Thanks in advance!
Re: New to me 170B
Posted: Mon Jun 22, 2020 5:21 am
by ghostflyer
You will love that single piece windscreen, the views are incredible . Just check it has been attached at the top correctly. The sloping nose of this Cessna model gives a great view. If the alternator is serviceable let it go until it dies. The rest are toys so have fun .
Re: New to me 170B
Posted: Mon Jun 22, 2020 6:37 am
by wabuchanan
If you ever have problems with your ADC oil filter set up, just replace it with the newer Tempest external spin on system. Many of us like ours.
Re: New to me 170B
Posted: Mon Jun 22, 2020 2:12 pm
by Deputydog
I have many of the same mods on my 170, you will definitely like those.. All are good upgrades. I have the Petersen Mogas STC, so I run that most of the time.
This is going to be a great first plane for you! Congrats!
Re: New to me 170B
Posted: Mon Jun 22, 2020 2:13 pm
by counsellj
Congrats on finding an airplane. Where will you be based?
Re: New to me 170B
Posted: Mon Jun 22, 2020 2:42 pm
by IP076
counsellj wrote:Congrats on finding an airplane. Where will you be based?
COE. Until I have my first born to sell to get a hangar at Felts...
Re: New to me 170B
Posted: Tue Jun 23, 2020 2:23 am
by rschreiber
Congratulations on the new addition! She sounds like a very well-equipped bird.
Re: New to me 170B
Posted: Tue Jun 23, 2020 1:17 pm
Most of us have teflon balls. David (ghostflyer) carries his in a wheel-barrow. :mrgreen:
Congratulations and DON”T SLIP IT WITH FULL FLAPS!
WELCOME!
Re: New to me 170B
Posted: Thu Jul 02, 2020 3:42 am
by IP076
Well, the sale all went through. My schedule didn't permit, so a good friend picked her up for me today and made it to his place in MI where it will be stored for two weeks while I finish my work rotation. Then some flying with a instructor for my insurance checkout, and some fun flying out there, then head west.
Here she is:
Can't wait to fly her around!
Re: New to me 170B
Posted: Thu Jul 02, 2020 10:28 am
by brian.olson
Congratulations!
Re: New to me 170B
Posted: Thu Jul 02, 2020 11:01 am
Very Pretty! Congratulations!
Any ADS-B equipment on board?
Re: New to me 170B
Posted: Thu Jul 02, 2020 11:59 am
by IP076
gahorn wrote:Very Pretty! Congratulations!
Not yet. Looking at ordering the UAvionix Tail Beacon.
Re: New to me 170B
Posted: Thu Jul 02, 2020 5:52 pm
Likely an excellent choice. It is written up about in this month’s Aviation Consumer. Contains it’s own txdr and is intended to meet expected Canadian ADS-B requirements. (Also, the wingtip fairings from a later Cessna model on your airplane does not accept the uAvionix SkyBeacon without an expensive adaptor.)
Re: New to me 170B
Posted: Thu Jul 02, 2020 6:09 pm
by rschreiber
Beautiful bird!
Re: New to me 170B
Posted: Thu Jul 02, 2020 6:59 pm
by IP076
There’s the tailBeacon and the tailBeaconX. I believe you’re referring to the “X”, which isn’t available yet for certified airplanes. I need to do a little more research as to which Canadian airspace requires ADS-B before I purchase, but I’m inclined to think I won’t be using the airplane much in those areas.
Also, I believe if you use the “X” you need an AVR-20 or -30 to function as a control head. I’ve got a fully functioning transponder.
