Who’s still using a C145?
Posted: Thu Aug 06, 2020 7:30 am
I had a broken lifter back in May when I bought my 170. Consequently tore it down and reassembled after specing everything out. Luckily crank and cam were within new spec.
Nobody had a new cam in stock so had to send mine out. Cylinders were a little easier to find but still had to order them from out of state. Oil pan was nonexistent and had to buy a couple until I found one with no corrosion.
Still cheaper then a 180hp conversion, since I stick fairly close to home it’s not really needed for my uses. If I need a bigger motor I switch to a different plane. Wondering who is still using the older C145, other then the broken lifter the inside of the motor looked mint.
