Re: Yoke and Yoke Shaft Refinishing
Posted: Tue May 04, 2021 1:05 am
I spent some time yesterday cleaning up the yoke bearing brackets and fine-tune sanding the Deltrin bearings (balls). The brackets were coated in some quite resistant grime that I attacked first with solvent (the bracket on the left of the photo has actually been thoroughly soaked and cleaned with solvent) and then finished with a Dremel. All four came out pristine.
I used sandpaper wrapped around a wooden dowel to sand the inside of each Delrin ball, first starting at 220-grit and finishing with 1200-grit to give a nice, smooth and form-fitting dimension.
Today, I reinstalled everything - first with the Delrin bearings and the brackets, and then the new universal joints (which arrived via USPS mid-afternoon). You can see the old vs. new joints in the following photo. I'll note that there is zero excess play with the new universal joints and the yokes are rock-solid, yet move easily in all directions.
Before wrapping up for the day, I pulled the throttle cable knob off and shot a photo of the completed project (at least this project). I'll strip the knob tomorrow evening and once the rains stop and the humidity drops I'll be able to paint with primer, the red color coat, and finally a few coats of clear coat to protect everything.
Very happy with the outcome and I feel much safer knowing the universal joints are new.
