Javelin AUX fuel tank
Posted: Tue Sep 29, 2020 11:56 am
by todd.mtn
During an engine change/annual/mini restoration on my ‘53 B, the Javelin AUX tank sending unit appears INOP. The ohms are all over the map and inconsistent with float movement. It shows an open circuit in the full position. I called Air Parts of Lock Haven. They needed a part number to do repair/rebuild. The Javelin install manual does not specifically list the sending unit part number. Do any members know what sender Javelin used for this tank? Thanks
Re: Javelin AUX fuel tank
Posted: Tue Sep 29, 2020 4:07 pm
Since my home was extensively damaged in a storm while I was away last convention most of my records/documents are still in storage so I cannot readily access the blueprints which might give that info...but this reminds me to readdress that ....
..Meanwhile, I seem to recall that one of our FL Members once found an exact replacement from O&N Modifications which were perfect fit/replacements for both gauge and sending unit. Unfortunately, O&N is no longer... the Olsons retired and closed their business. Their STC, however, was purchased by Griggs Aircraft who might be able to provide the info as to what PN’s the O&N Aux tank for the C-172.
http://griggsaircraft.com/fabrication/aux_fuel_systems
http://griggsaircraft.com/contact
Posted: Tue Sep 29, 2020 7:34 pm
by todd.mtn
Thanks George, appreciate that info. I’ll run down those leads
Posted: Tue Sep 29, 2020 10:15 pm
I have found my blueprint and see that the “gage” is mfr’d by AC, and is PN 6430693. The blueprint does not provide the make/model of transmitter, but I’ll keep looking for info.
BTW, FYI, the fuel cap is a “Gates GAS 20”.
Posted: Wed Sep 30, 2020 12:01 am
by todd.mtn
Every bit of information about this system will help to get the right parts. Thanks for diving into your storage bins for this info
Posted: Wed Sep 30, 2020 4:00 pm
I’m having the entire blueprints, installation instructs, pics of fuel system routing, AFM supplements, etc digitized and should be able to upload it to the Mx Library soon.
Posted: Wed Sep 30, 2020 5:55 pm
OK, well with some “sleuthing” I have come up with a PN and mfr’ for the sending unit: Stewart-Warner PN: 385C-F
https://www.summitracing.com/parts/sww- ... 3QQAvD_BwE
The gauge is likely: PN: 385M.
https://www.summitracing.com/parts/sww-284m
Hope this helps.
Posted: Thu Oct 01, 2020 5:49 pm
by todd.mtn
Fantastic George! That will enable me to get a new gauge to match the ohms on that sender. Was that sender part number on the Javelin blue prints??
Posted: Fri Oct 02, 2020 10:08 am
todd.mtn wrote:Fantastic George! That will enable me to get a new gauge to match the ohms on that sender. Was that sender part number on the Javelin blue prints??
No. It’s a (non) PMA equivalent.
