Replacement oil pressure line
Markjobe
Post by Markjobe »
Time to replace the original (1951) oil pressure line. Anybody found a source for a braided line? Saw a picture somewhere where someone had installed one after a copper line failure but can’t find it anywhere. Any recommendations?
C170A N1493D serial #20095
Re: Replacement oil pressure line
See this thread: viewtopic.php?f=24&t=11983&p=112727&hil ... se#p112727
I made my own by ordering the materials from Spruce. A Mandrel is not needed for 1/8” hose.... you can use the smooth shaft of a 1/8” drill bit. Pressure-test it by plugging one end and pressurizing it with air while submerging it in water.
Custom hoses may also be ordered thru Spruce. Stratoflex makes 3/16” primer fuel lines for Pipers or according to custom orders, with 2D end fittings.
Aeroquip 303 in 1/8” size hose can also be used with oil (despite being described as for air) if you wish to make your own.
C170U2
Post by C170U2 »
It is a really good idea to check your flexible oil line and replace periodically. I just removed the flexible line on my 120 and the fittings were extremely loose and I am shocked it didn't bust and dump oil overboard. I should have replaced this hose much earlier and feel lucky I didn't have a problem. It had been on the on the aircraft at least 12 years. :oops: Hoses have a service life, and with the smaller dimensions and less material in these small oil pressure hoses it is a good idea to replace regularly. I'm planning or replacing every 5 years going forward.
Most Pt 135 Ops have limits such as at Engine TBO or a chronological limit on flammable fluid hoses FWF.... (a typical limit is 5 years).... The C145/O300 engine has a TBO of 1800 hrs or 12 years whichever occurs first..... Certainly a good rule to consider.
On a 170 the gascolator to carburetor was originally a plain rubber hose... One might consider ordering a FireSleeved hose for replacement.
RobfromME
Post by RobfromME »
Good afternoon, all,
What is the proper bulkhead fitting for the oil pressure line for a 1953 170B? Also, how do you get the air out when adding kerosene to the hose running from the bulkhead to the instrument? Just patience as it comes back up the tube your filling?
Thanks in advance for your time and assistance!
All my best,
Rob
1953 170B
N3142A
RobfromME wrote:Good afternoon, all,
All my best,
Rob
It’s unnecessary to do that. The kerosene in the lower portion (between engine and firewall) prevents the oil from coagulating.
RobfromME
Post by RobfromME »
Thanks!
Very much appreciated.
All my best,
Rob
1953 170B
N3142A
Also, to update this subject….
Precision Hose Technology is who supported us this last year by mfr’g an oil pressure sense hose for the maintenance seminar…as well as supplied us with their complete hose specification booklet handout. They are also able to make the oil pressure hose for your airplane.
They can make up a hose using 193-2 hose (19-20 inches recommended for the standard airplane…. measure yours for a custom length)
…and 311-2D end fittings (female nipples). Precision Hose Technology is a Stratoflex shop.
https://www.aircrafthose.com/custom-quote
800-331-5946
RobfromME
Post by RobfromME »
Thanks so much for the information! Very much appreciated. You read my mind...I was going to ask a good source to procure the hoses from.
All my best,
Rob
1953 170B
N3142A
msheen
Post by msheen »
I'm glad to see so much discussion on this topic as it's exactly what I need as well, already reached out to Spruce about a SF193 hose with -2 fittings. Need an opinion on filling the line with kerosene.
Do I fill the line with kerosene, then connect the bulkhead side first? Is it the "finger over a drink straw" effect that keeps the kerosene from draining into the oil sump?
DWood
Post by DWood »
Might also consider PTFE hose assembly from Spruce AE3660240B0180
The 0180 is 18 inch and you might need a different length.
msheen wrote:I'm glad to see so much discussion on this topic as it's exactly what I need as well, already reached out to Spruce about a SF193 hose with -2 fittings. Need an opinion on filling the line with kerosene.
The kero in the line is intended to prevent/delay coagulation of oil in cold wx. I’ve never experienced that since I converted to the hose about 15 years ago. The larger volume of the hose may be the reason.
Kelley
Post by Kelley »
Gentle People:
The 19” or 20” oil pressure hose length mentioned, is that measurement from the engine pickup to the back of the oil pressure gauge?
Is enlargement of the hole thru the firewall needed to accommodate the fitting and/or the hose itself? Lastly, those of us using Shell oil is an additive recommended when using AeroShell W15W-50 while living 100% of the time in Mid-Florida? I pre-thank you for addressing these questions! Joe Kelley, N3448C
Kelley wrote: Tue Aug 27, 2024 6:11 pm Gentle People:
The hose is fitted between the engine and the firewall…which has a bulkhead connector….usually an AN832. (not found in the parts catalog..but see the pic) The copper line from INside the firewall to the gauge…has never been a problem because that line does not “shake, rattle, and roll” with engine movement.
No additive is necessary when using AeroShell 15W50,…not matter where you live. IMO
Kelley
Post by Kelley »
Thank you for an immediate reply, without the organization’s help, I’d definitely would be up the river w/o a paddle! Kelley
