We need a “LIKE” emoticon!Joe Moilanen wrote:This was my answer to the one inch socket.
4518C
oil filter adapter SB
Re: oil filter adapter AD
- Joe Moilanen
Thank you George! I guess necessity is the Mother of invention!GAHorn wrote:We need a “LIKE” emoticon!Joe Moilanen wrote:This was my answer to the one inch socket.
4518C
- mmcmillan2
Mine is a few years old, had the hex head bolt. Fiber gasket was fine, but i was able to rotate the assembly by hand. My mechanic reinstalled with two copper washers per the current instructions. Looks good after my test flight.
Re: oil filter adapter SB
My answer to the 1” square socket problem. 1” to 3/4” adapter with a 12 point 7/8” socket stuck on the square 3/4” male end. Glad to have the SB done, although mine had never leaked with the fiber gasket.
- Attachments
- F3D6169D-9863-45F7-A9EE-6AAFB7B3C136.jpeg (18.76 KiB) Viewed 3054 times
Paul, you have a 1" to 3/4" adapter you must work on Kubota Tractors.4583C wrote:My answer to the 1” square socket problem. 1” to 3/4” adapter with a 12 point 7/8” socket stuck on the square 3/4” male end. Glad to have the SB done, although mine had never leaked with the fiber gasket.
Strangely enough I have two of those adapters and no 1” drives...don’t know if I could pick up a 1” drive ratchet anymore!johneeb wrote:Paul, you have a 1" to 3/4" adapter you must work on Kubota Tractors.4583C wrote:My answer to the 1” square socket problem. 1” to 3/4” adapter with a 12 point 7/8” socket stuck on the square 3/4” male end. Glad to have the SB done, although mine had never leaked with the fiber gasket.
Here’s another option.. 1-inch, 8-point, 1/2” drive: https://www.amazon.com/gp/product/B007Y ... UTF8&psc=1
