Nose Bowl Replacement
I finally started on repairing my 48 cowl. I’m currently concentrating on the nose bowl. Today I removed the nose bowl and subsequently discovered I need left and right angle rub strips p/n 0552000-9 and -10. Does anyone have a lead on where to get them. The originals were spot welded in place, my strips are not salvageable.
Re: Nose Bowl Replacement
You are very likely going to find it easier/simpler to make them yourself.... but Textron (Cessna) and AeroVal claim to have them available...IF you request a “quote”. Good luck with that.
Kind of expected that response...... anyone have a pre 52 lower cowl?GAHorn wrote:You are very likely going to find it easier/simpler to make them yourself.... but Textron (Cessna) and AeroVal claim to have them available...IF you request a “quote”. Good luck with that.
I see curved wooden blocks in your future....or Univair if you scratch and win big
I finished the angles today. Yes wood former and plenty of hammering
Angle install pics
- Attachments
- 1B3C716F-962A-42EE-87A2-0B94754A81EF.jpeg (31.76 KiB) Viewed 7821 times
- F8C8AD4D-B2C2-4608-ABC1-577B0F174C7D.jpeg (31.63 KiB) Viewed 7821 times
Moving along today I riveted the bowl to the main lower cowl skin. I will post the pics tomorrow. I was so busy I didn’t take pics today. Here are some of the pre-riveting cowl
- Attachments
- 6FE153B0-6E22-4276-B38A-9792E33C30EE.jpeg (38.11 KiB) Viewed 7820 times
- 2F292E36-2047-4008-912B-96D7BB48CD07.jpeg (37.11 KiB) Viewed 7820 times
- 8BD9A664-E678-4B47-A45D-E9AAB87C332C.jpeg (35.66 KiB) Viewed 7820 times
Pic of the original bowl. After 73 years there have been numerous repairs
- Attachments
- 374646EC-68B6-464B-AC21-C7D0823AEE18.jpeg (49.1 KiB) Viewed 7820 times
- 44B4E824-8FE2-4389-AEED-10F49E1C2F76.jpeg (47.37 KiB) Viewed 7820 times
- 82D0D57F-6487-402A-878F-35022E6C883E.jpeg (41.06 KiB) Viewed 7820 times
- 009812CF-8023-4907-AC97-813BD8828DAA.jpeg (35.9 KiB) Viewed 7820 times
- 38FAD5AF-5BF5-4C3D-92D9-F0A2A7D14B2A.jpeg (31.62 KiB) Viewed 7820 times
So tomorrow’s plan is to paint strip the grill vents and install then. Then install the winter front doubler and anchor nuts. Then continue work on the air inlet.....I have some mods that I’m considering.....certified of course. Also, every cowl screw fastener, previously tinnermans will be replaced with floating 10/32 anchor nuts and SS screws. Plenty of work but a worthy enhancement.
Nice work on the cowl. Thanks for the pics.
Great-looking work! Thanks for the pics.
Is that a replacement Cessna nosebowl or did you make it yourself?
The new nose bowl is an NOS part. Keep in mind it is only a shell. There are no doublers/frames/stiffeners. You need to build them, or salvage from the old nose bowl. My nose bowl was beyond repair or salvage so I had to get creative and manufactured the frames. Moving forward, today I completed stripping the the grills and prepping them for install. A rivet squeezer is the best tool for this job. I also reinstalled the anchor nuts for the winter fronts. Couple of pics from today...the cowl is framed up and fits well. Tomorrow I’m working on the intake. As I said I have a plan for something new rather then the original cumbersome air scoop. Cheers all
Air scoop arrived. Sheet metal work coming up, plenty of cutting and fitting, rivet tomorrow
Carbon fibre ? My aluminum has a few cracks, stop drilled but unsightly, might have to go that route.
