Aileron bellcrank bolts
Posted: Thu Feb 18, 2021 6:51 pm
Gentlemen,
I'm finishing up replacing all the control cables, pulleys, turnbuckles, etc. and I'm a bit confused at the aileron bellcranks
The '48 IPC shows AN3 bolts but the fittings are all drilled 1/4 inch (AN4 holes). There is no mention in the IPC of bushings, but I have found bushings on most (but not all) of the bolts I'm removing.
The fitting in the photo has a bushing jammed into it, but the replacement cable has no such bushing.
Are bushings typical on these bolts or are the AN3 bolts supposed to wallow around in 1/4 inch holes?
Gareth.
Gareth.
