Plexiglass Panel Overlay - 170A
brian.olson
Re: Plexiglass Panel Overlay - 170A
Post by brian.olson »
Some additional progress over the past couple of days, and some interesting observations to share.
First off, I did my first cut of the completed plexi overlay but enlarged the cutout holes to a point where they could slide over the top of the knobs on the panel and thus check alignment. Everything checks out perfectly - text, holes, grid, etc. So, we have that behind us.
Second, I decided to run a test just to see if there was any difference between painting the back of the plexi (after the engraving had been filled in) vs. painting a piece of aluminum with the back color and pressing it up to the back of the plexi panel. Big surprise for me: painting the back of the plexi toned-down the colors and in darker lighting it became very difficult to read the labels. However, the piece which was left clear positively glowed in all light. I should have expected this - undoubtedly the plexi's index of refraction is bouncing light all over the place when the panel is left clear. Additionally, it now seems apparent that one really solid reason the chamfer is at the top is to let more light in, and thus amplify the readability.
The results are pretty startling - note that both examples have the same engraving, the same paint used to fill the engraving, and the same back-color paint:
Last night I did a first-pass print of the final piece utilizing a piece of painted backing material. There will be another final-final printed that I will chamfer with a router and then polish.
For better or worse - this is as far as I can go before I find an A&P both smart and talented to pull out all the cables so we can install the new piece. Likely, this will wait until my annual inspection later this fall. At that point I'll be able to definitively answer - at least for my plane only - was the plexi painted or was there a piece of aluminum painted behind it. I'm very curious to see what we uncover :)
Thanks again for all the great input and discussion over the past week or so - it's been a fun learning experience.
(Pardon all the dog hair in the photos. You think you get it all cleaned off, and then more appears again before you know it)
Brian
1950 170A
N5762C s/n 19716
dstates
Post by dstates »
Great work, Brian!!!
I may have to put in an order for one ;)
Very nice work!
So Brian, since you have the system perfected, does this mean you will be making custom plexi-overlays? Some of us have non-stock control cable and switch position layouts marked with label-maker labels. It would really be nice to have correct labels on the overlay.
brian.olson
hilltop170 wrote:Very nice work!
While it was never my intention to go into production, per se, that's certainly doable Richard. I only have dimensions that I have taken from my 170A, but within those bounds it would be pretty straightforward to customize the control cable and switch positions as well as change the labels as-needed. I'm certainly looking forward to the day that I can remove the vinyl labels!
Brian
1950 170A
N5762C s/n 19716
Can you make one for my ‘53 B-model where the Park Brake label is changed to “PLACEBO”…..?? :lol:
brian.olson
I was thinking about "DON'T PULL THIS KNOB!"
Brian
1950 170A
N5762C s/n 19716
Thank Brian! I would like to have you make one for me if/when you feel like it. PM me when the time comes and let’s discuss it. Richard
barrymaas
Post by barrymaas »
This is great, Brian!
Can you share your final cut file? You did a great job getting all the cuts lined up
brian.olson
Barry - this is the final (as of now) cut file. The forum wouldn't allow me to upload the file in the .svg format, so you will need to unzip the file prior to use.
Brian
62C Plexi Panel v2-3.pdf
(17.62 KiB) Downloaded 299 times
62C Plexi Panel v2-3.zip
(8.18 KiB) Downloaded 277 times
Brian
1950 170A
N5762C s/n 19716
Brian, just caught up with your work. Looks very nice.
Very interesting, the observation between painted back and clear panel laying on a painted surface. Could this be another watershed moment when the traditional thought process, that these panels where painted on the back, starts to change. Old assumptions die hard but it makes sense that they wouldn't be painted on the back for the reasons of light refraction you've shown and also simplicity of manufacture from Cessna. They wouldn't have to stock but one panel, not all those with different paint.
Ryan Smith
Post by Ryan Smith »
Bruce Fenstermacher wrote:Brian, just caught up with your work. Looks very nice.
Show me the screws mounting piano keys on any old panel behind an untouched plexiglas overlay.
The fact that they’re not visible indicates the panels were, in fact, painted.
brian.olson
And the answer is, at least for my aircraft: the plexi overlay was painted on the back. It was not clear with a painted panel showing through.
Brian
1950 170A
N5762C s/n 19716
brian.olson
FINAL POST
I wanted to close the loop on this series of posts to give a final readout of the project, with hopes that anyone wishing to duplicate this can skip right to the finish line without suffering the experimentation.
Plexi (Acrylic) Overlay Panel:
As indicated previously, in my plane the back side of the original acrylic panel turned out to be painted.
The final copy of the acrylic panel has been completed and installed during 62C's annual inspection. The panel was cut/engraved on a Glowforge laser cutter/engraver. I tested three different suppliers for the acrylic, but the final acrylic was sourced from Glowforge itself and I determined it to be the best. It is 1/8" thick. As near as I can tell it is UV-resistant. The original acrylic that was in the plane measures 3/16" thick (see "future considerations" section below).
The "back" side of the acrylic was first sprayed with four coats of custom-mixed automobile base coat enamel which I had color-matched from a can of the original clay/maroon paint by a local auto paint supplier. The acrylic overlay was then cut/engraved 24 hours after the final coat of paint was applied. The engrave file was cut/engraved in "reverse image" so that it engraved through the paint just into the acrylic.
Laser settings used (these are pretty important, as I did an unusually large number of tests to determine the best engrave depth, etc):
Outline and Holes: use the standard Glowforge setting for "cut".
Lettering: use "Engrave" option with the following settings - Speed: 600; Power: 16%; Lines per Inch (LPI): 450 LPI.
Grid lines: use "Score" option with the following settings - Speed: 300; Power: 20%.
The lettering was then painted into the engraved portions using an automobile detailing brush. Two coats of paint were applied to ensure opacity. I originally tested four different types of paint and found that pretty much any type of acrylic paint worked great. I used "Golden Fluid Acrylic" brand acrylic procured from a local Michael's. White is "Titanium White" and the yellow is "Benzimidazolone Yellow Medium". 12 hours after the final coat had dried I applied a protectant coat of automobile 1k clear coat as a protectant (although pretty much anything will work).
Alignment of the holes had been worked out previously with draft copies of the overlay, though we discovered some fine-tuning had to be done during the actual installation; for that purpose we used a Dremel with a sanding drum. A new mixture cable was installed due to the old one being unserviceable. Additionally new carb heat and starter cables were installed because we needed to replace the "silver" knobs that were in the panel with originals (see section on "Knobs" below). There were minor variations in fitting diameters that needed to be accommodated. In the end, we also discovered that the throttle cable needs to be replaced as the old one is also unserviceable, and we are currently waiting on delivery of that cable.
Because the acrylic was 1/8" thick we did not need to bevel the top edge of the acrylic panel.
The new acrylic panel was written up in the log as an "owner produced part" as part of the annual inspection.
Acrylic Panel - Future Considerations:
I do have some lingering concern over the 1/8" thickness of the acrylic and its ability to stand up over time. The engine controls exert a lot of the tension at the attach points and the motion of the cables during flight, over time, may lead to localized cracking. My first impression is that with the strong aluminum panel behind it, it should hold up and not be subject to stress cracks. If I was to do this over again I might spend more time sourcing an exact 3/16" sheet, and may also have spent additional time testing standard acrylic vs. polycarbonate for rigidity. Although an option, I believe 1/4" acrylic would be too thick.
While I do not have immediate concerns over paint fading, I will be curious to see how the yellow and white acrylic paint holds up. The automobile paint is designed not to fade, so I do not have concerns over the base color. HOWEVER - it should be noted just how much the original panel faded from maroon to its dull brown equivalent over seventy years. Time will tell how the new acrylic panel holds up.
Knobs:
In a recent post (viewtopic.php?f=24&t=15840) I explored casting new knobs for the panel to replace missing originals. As original knobs are difficult, if not impossible, to find, I used the knob from the cigarette lighter to create silicone molds, then poured resin castings. For the draft versions of the knobs I utilized press-fit brass threaded inserts to accommodate the cable ends.
In the final product, I used EpoxaCast 650 high strength resin and the ExpoxaCast HT (high temp) hardener. 650 is designed for industrial high-impact tooling applications and the addition of a high-temp hardener raises the critical temp of the part well over 200-degrees F. Rather than press-fitting the threaded inserts I designed a mechanism to allow the inserts to be held in-place during the curing process, so they are an integral part of the knob.
The resin cured in-mold for 24 hours and then is further cured for two hours at 175 degrees F, followed by 3 hours at 300 degrees F. The feel and hardness of the knobs is indistinguishable from the original. As a test I performed some unscientific pull-testing using a vice, a threaded rod, and pliers, and was unable to get the part to fail. The only way I was able to fail the part was by viciously beating the hell out of it with a hammer that put the opening scene of 2001: A Space Odyssey to shame. I am thoroughly convinced the aircraft will disintegrate before the knobs will.
During the mixing process the resin was color-matched using resin coloring pigment by my patient wife. It took us (her) three times to get it right, as the color changed from the original mixing towards the brown end of the spectrum during the heat curing process. In the end we were able to get knobs that are a direct match to the knobs currently in the panel. For your reference, the carb heat and starter knobs are new.
The new knobs were also signed off as an "owner produced part" in the logs as part of the annual inspection.
Future Considerations - Knobs:
None - it was a lengthy process but I'm proud of the knobs we were able to create.
Photos:
Photo 1 - the original acrylic panel and silver knobs:
Photo 2 - compare of the front side of the original and new acrylic panels:
Photo 3 - compare of the back side of the original and new acrylic panels (note: the new acrylic panel is actually a back-up copy of the one installed in the aircraft, and did not have the final protective coat of paint applied to the backside, as I wanted to show how the lettering and lines were filled in):
Photo 4 - the "nearly" completed install. Note the new acrylic panel is in place. The new knobs for carb heat and starter are in place. The new throttle cable has not arrived, thus there is an open spot on the panel. The decorative instrument panel overlay has not been installed):
A huge thanks to member Barry for providing the original template, which gave me a great starting point to begin the creation of the design file, as well as the large number of members who provided guidance and input during this process. It is very much appreciated.
Brian
1950 170A
N5762C s/n 19716
Wow. That's a lot of work. But the result looks very nice. Actually "very nice" doesn't do it justice.
Brian,
That is some amazing work! Thanks so much for taking the time to write up all the details of how you did it. I find it interesting that both you and Ryan appear to be correct on the overlay panel font. Compare the "W" on your original to that of a C-170B overlay -- they're done with different fonts -- apparently Bernhard Gothic and then later using Century Gothic Bold. I wonder at what serial number the switch was made.
