Carb Heat box
Posted: Wed Oct 06, 2021 12:20 am
by Joe Moilanen
Has any company that anyone knows of produced an approved carb heat box that is worthy? I need to at least replace the butterfly shaft and bearings, but would like to replace the whole box if I could find a good one. TIA
Joe
4518C
Re: Carb Heat box
Posted: Wed Oct 06, 2021 2:21 am
As you know, Joe, Spruce, Wag-Aero, etc all offer an airbox that has no official approval and relies upon the owner and/or his inspector to find an approval basis for it. That is a poor method but one to which some owners have successfully resorted.
When my 172C airbox was found to be in shambles…. I mailed it to Del Lehman in Mena AR … and a week later…. a rebuilt/practically new airbox was returned to me complete with an assortment of hardware to re-attach the carb-heat control cables. I considered it a god-send.
No paperwork was requested, expected, or supplied….but its airworthiness is without question. (The mx record states that the airbox was “repaired and returned to service”.)
Re: Carb Heat box
Posted: Wed Oct 06, 2021 6:38 am
by pdb
Atlee Dodge does great work rebuilding airboxes as well.
https://fadodge.com/services/
Re: Carb Heat box
Posted: Thu Oct 07, 2021 1:10 am
by Joe Moilanen
GAHorn wrote:As you know, Joe, Spruce, Wag-Aero, etc all offer an airbox that has no official approval and relies upon the owner and/or his inspector to find an approval basis for it. That is a poor method but one to which some owners have successfully resorted.
I bought one from Wag-Aero years ago and sent it back, it was pretty bad... My airbox looks like it has had a lot of "body and fender" work over the years. My 0-300D came off from a 172 before I owned the plane, it may have nosed over at one time or something happened, it's had some damage. I'll probably just re-bearing the butterfly shaft and call it good if I don't find one. It works fine I'd just like to get a better one if I happen to run across one
Joe
4518C
Re: Carb Heat box
Posted: Fri Oct 08, 2021 2:37 am
by sgrimsley2717
Check with Fresno Airparts. I purchased a new one two years ago. They sill list this part but it is expensive. Current price is now $1275. It was $300 less when I bought mine. Look on page 15 of the section for C-145 engines. These are difficult to find in decent shape on the used market. You can also search on Ebay. Good luck.
Re: Carb Heat box
Posted: Sat Oct 09, 2021 1:43 am
by Joe Moilanen
sgrimsley2717 wrote:Check with Fresno Airparts. I purchased a new one two years ago. They sill list this part but it is expensive. Current price is now $1275. It was $300 less when I bought mine. Look on page 15 of the section for C-145 engines. These are difficult to find in decent shape on the used market. You can also search on Ebay. Good luck.
Thank you! I'll check them out.
Joe
Re: Carb Heat box
by Joe Moilanen
pdb wrote:Atlee Dodge does great work rebuilding airboxes as well.
Thanks!
