Prices here, and there?
Posted: Thu Apr 15, 2004 7:14 pm
by Alterfede
folks, this are the prices of the stuff i need to have FEH back in the air, i know is not much, but i wonder if our prices have a big diference with yours
6 rings set in .015 $251
12 rubber seals for pusghrod tube $20
6 intake manifold rubber tube $15
cilinder base o ring $6
6 intake gaskets $12
6 valve cover gaskets $38
6 exhaust gaskets $12
12 valve guides $124
6 pistons in .015 $277
1 cylinder in .015 $500
prices are in dolars and without taxes or shipping.Saludos
Posted: Thu Apr 15, 2004 11:51 pm
Fede, you can view prices at the online catalog at
http://www.aircraftspruce.com/
Posted: Fri Apr 16, 2004 1:29 am
by R COLLINS
CONT. C-125-145-0300
Top Overhaul Gasket Set (No Rubber)......................$36.50
MOH Gasket - Hose Set ............................................137.50
Ring Set Std., +.005, or +.015 (Early $115.00) Late 145.00
Crankshaft Seal Assy. 539241 (530917SS) ................24.50
Brg. Set, Std., Thrust Washers (U.010 - $397.50) ....357.50
Crk/Shaft C/WGT, Bush, Pin, Plate Set (145-2,0300)337.50
Valve Spring Set, Complete (36 Ea. Springs) ............93.50
Piston 40327, Std. or +.015 C125 ..............................77.50
Piston 530348 Std. or +.015 C145-0300 ....................47.50
Piston 646255 Std. or .015, Late ................................67.50
Camshaft 643068 Std. (SS530803 Grd.-Tagged $525) ..700.00
Cam Follower Body 530851 (Grindable Exchange)....92.50
Cam Follower, 530851 (Cert. Recond.) ......................57.50
Fuel Pump, New, 40585, C125, C145-2, -2H ............295.00
Oil Pump OH Kit 23403/35343/23410/22537............392.50
Housing, Tach Drive 35342 Recond............................67.50
Crankcase Thru Bolt 7/16", 531211 ............................29.50
Crankcase Clamping Bolt/Nut Set ..............................62.50
Carb. Air Filter/Bracket BA5110 (BA6108 $11.00)......52.50
Shielded Ignition Harness (Advise Mags) ......From 187.50
Lord Mount, Engine 23411 ..........................................37.50
Magnetic Oil Sump Plug ............................................17.50
Oil Quick Drain TCM 0-300,C145 1"-18 ......................67.50
Fede, This is an ad from Fresno Airparts. I have done business with them before with good results. Their phone no. is 1-559-237-4863. The prices you listed weren't too bad, but on the exhaust gaskets I would use the no-blow type, they are more expensive but worth it. Hope this helps. Randal
