Changing Filter/ Screen without draining oil?
Posted: Tue Nov 29, 2022 4:07 am
by Marion
On the 0300, I need to remove the screen and would like to do it without dumping the oil. Does anyone know if I can do this or am I going to have an oil spill?
thanks
Re: Changing Filter/ Screen without draining oil?
Posted: Tue Nov 29, 2022 5:45 am
by pdb
I am no expert but my guess is you are going to have a mess.
Even if you drain enough oil into a clean bucket so that the level is below the level of the oil screen, there is going to be enough residual oil in the screen housing and line to make a mess if you aren’t very careful and maybe a bit even if you are.
Posted: Tue Nov 29, 2022 6:32 am
You are going to have to drain the oil.
Posted: Tue Nov 29, 2022 6:26 pm
by Marion
