Starter Button Replacement?
dav8or
Post by dav8or »
Does anyone know where I might be able to find a replacement for the starter button on a C-145?
The spring seems to have collapsed and does not push the button back out anymore. If there is a way to replace that spring that would work but it doesn't look like there is a way to reassemble that part. I have tried Napa but the only button in their book appears to have different dimensions that would place the button closer to the arm that actuates it.
Thanks,
Dan
Re: Starter Button Replacement?
Dan,
I’m guessing the switch that didn’t match was Delco-Remy p/n 820052.
Is that correct? It seems to me - if you could find the appropriate rivet - you could transfer the button/spring assembly from this incorrect aftermarket switch to your old switch assembly for under $20. This guy has switch p/n 1904305 for sale. Hard to tell if that would fit. Here’s a picture of my starter switch.
Surely one of us has one in their junk box to sell.
And then theres the Tractor Supply Company aviation dept: https://www.tractorsupply.com/tsc/produ ... tch-820052
same switch on John Deere Model A, B, 50, and 60 tractors.
dav8or
Post by dav8or »
Hi,
The second one Gary posted is like mine. The Delco-Remy p/n 820052 in the other picture is like the one I purchased with different dimensions. When installed on the starter the "button" is closer to the arm/bolt that engages it. I might try drilling a second set of mounting holes in the longer switch but not sure it would still connect properly with the contact on the starter.
If I could figure out how to re-do the rivet I would definitely try transferring the button/spring from the new one. I think I will try contacting the supplier that made this particular aftermarket switch to see if they might be willing to sell me a button/spring assembly that has not been riveted yet.
Thanks,
Dan
dav8or
Post by dav8or »
I sent a message to that ebay seller requesting a picture of that switch from the side. It appears that it might be correct. Thanks for that link.
Thanks,
Dan
mschlender
Post by mschlender »
I should have a spare
dav8or
Post by dav8or »
That ebay part was the correct one. One issue down many more to go.
Thanks,
Dan
Good to hear!
