Higher oil temps with Phillips XC20W50 ?
- BrianW
I've switched to using XC20W50 because I fly over 150 hours/year, and the temps where I fly vary a lot. My last trip from Michigan to Arizona, I had temps in the low 30s up to 90s. One downside I've noticed, it it seems to have higher oil temps than when running 100W. The temp gauge was almost in the yellow on a day that was only 75 degrees at the altitude I was flying. Worried it would probably be in the red on a hot day. I did recently put on the spin on oil filter adapter, and didn't move the blast tube (Maybe I should?). So far the temps have remained in the green, but sometimes at the very top of it. Any suggestions ?
Re: Higher oil temps with Phillips XC20W50 ?
Sooo…you’ve made TWO changes then…?? Oil type AND spin on filter?
- bjan11
I would be much more suspicious of your new oil filter adapter than the oil. I wonder if something isn't flowing right, and that's preventing oil from flowing through the filter (/cooler, if you have one).
Had a similar issue ,but was using Exxon 100w and switched over Phillips multi grade. I couldn’t change the direction of the blast tube and purchased a finned heat sink that attaches to the spin on filter. This clamped around the filter. I purchased it off Spruce. I was too minds about changing over the oil type due to the age of the engine as I was now using a detergent type oil. However the sump had been removed and cleaned and other engine work had been done . engine oil temperature was now satisfactory. [ PS. I am now NOT a fan of Exxon oils.]
I cannot imagine how oil would not flow thru that filter. If, for some reason that were to occur, then there’d be no oil pressure indication. (The pressurized oil route is the same whether a filter or the OEM screen is used.
When I had a Baron I ran an experiment in which I switched one engine over to AeroShell 15W50 from the 100W I’d been running in both engines. The engine with the 15W50 ran slightly warmer and leaked a LOT more than it did previously. I switched back to straight 50 wt oil.
If you want to see if it’s the oil or the filter adaptor modification…. switch the oil back to what you were previously using and see.
