New Flap Tracks
reecewallace
New Flap Tracks
Post by reecewallace »
I need new flap tracks & rollers for my 56 170b.
Both flap tracks have significant wear and make 'clunking' noises as they roll through the 40 degrees, catching on wear notches in the tracks.
I'm unable to find the flap tracks or rollers in the parts catalog.
Can anyone assist me in telling me which p/n they are? Also, on which brand/where to purchase?
Is there anything else I need to know/order for my AME to replace these?
- Reece
1956 Cessna 170b
Nanaimo, BC Canada
Re: New Flap Tracks
Flap tracks and roller kits are available from McFarlane: https://www.mcfarlaneaviation.com/search/?q=flap+track
reecewallace
Re: New Flap Tracks
GAHorn wrote: Fri Jan 19, 2024 3:54 pm Flap tracks and roller kits are available from McFarlane: https://www.mcfarlaneaviation.com/search/?q=flap+track
Which ones though? There's tons of options. I can't find the p/n's in the IPC
- Reece
1956 Cessna 170b
Nanaimo, BC Canada
Re: New Flap Tracks
McFarlane can likely identify the necessary PNs for you but….. MC0523231-14 is what you need… Four of them.
(Fig 8, Item 45) “Rib Assy”…..PN 0523231
reecewallace
Re: New Flap Tracks
GAHorn wrote: Fri Jan 19, 2024 4:12 pm McFarlane can likely identify the necessary PNs for you but….. MC0523231-14 is what you need… Four of them.
Thank you.
- Reece
1956 Cessna 170b
Nanaimo, BC Canada
Re: New Flap Tracks
I wouldn’t be too worried if the tracks were “worn”. but that’s just me unless of course the wear is silly. More problematic is the lateral wear of the rollers through the flap side arms which will lead to a possible failure flap jam and asymmetry.
Re: New Flap Tracks
c170b53 wrote: Fri Jan 19, 2024 4:31 pm ... unless of course the wear is silly. ....
Is silly a Canadian measure Jim? Do you know if it is a skosh more or maybe less than "a wee little bit"? We need to know. :lol:
Re: New Flap Tracks
Its hard to imagine how the tracks can become worn unless the rollers have been neglected and have frozen along with not lubricating the tracks. If there’s something thats easy to do on a 170, it would be that lubrication hence Reese you might be in for a world of hurt the deeper your task takes you of which I hope is not the case. PM me if you need to borrow the gauge.
Re: New Flap Tracks
Ah…you got me Bruce, yes the measure is a variable measure dependant on the amount of quaffing going on :D
sfarringer
Re: New Flap Tracks
Post by sfarringer »
Just guessing that quaffing is an integral part of the flap track replacement process. 8O
Ragwing S/N 18073
Joe Moilanen
Re: New Flap Tracks
Post by Joe Moilanen »
c170b53 wrote: Fri Jan 19, 2024 5:59 pm Ah…you got me Bruce, yes the measure is a variable measure dependant on the amount of quaffing going on :D
The Maximum flap track wear dimension is .6035. If it is over this dimension anywhere in the track slot they recommend replacement. McFarland sells a gauge for $41.25 ( Part # 950) but I just turned a piece of round stock down on a lathe to these dimensions to periodically check with.
4518C
Re: New Flap Tracks
I’ve never had to replace one, couldn’t get the gauge to fit anywhere and I actually had a substantial amount of overspray to remove . Plane just crossed 4000 TT and I’m thankful. Looking at the job Im guessing there be something more than a wee quaffing .
