Tail U-Bolt
Posted: Thu Feb 15, 2024 8:29 pm
by Jim Collins
Hey All,
I am looking for a lead on where to get the tail wheel leaf spring U-Bolt #0510000-32 as mine is a bit bent up
I tried Univair, Stoddard, Yinling, Controller, and Ebay to no avail.
I suspect this may be a hard to find item.
Any help would be great
Jim Collins
N2488D 170B 1952
Re: Tail U-Bolt
Posted: Thu Feb 15, 2024 8:38 pm
by brianm
I'd check with Air Repair. They carry a ton of L-19 parts. The L-19 part number seems to be 0642133 or 0642154, but I bet there is a good chance that it is exactly the same as the 170 part.
Re: Tail U-Bolt
Posted: Thu Feb 15, 2024 9:06 pm
by Jim Collins
Thanks Brian,
That was an excellent recommendation as they had one in stock and I ordered it
Thanks again
Jim Collins
N2488D 170B 1952
Re: Tail U-Bolt
Posted: Thu Feb 15, 2024 9:11 pm
by Jim Collins
George,
I may have been too fast in ordering.
I looked at the part number you gave for Aircraft Spruce and that is the main spring. I was asking about the U-Bolt.
Does the L-19 U-bolt #0642133 fir our birds? Because that is what I ordered.
Jim Collins
Re: Tail U-Bolt
Posted: Thu Feb 15, 2024 9:27 pm
by gfeher
Jim, yes, the L-19 U-bolt is tha same as the 170B one. You can order it from Air Repair using either the number you used or the 170B part number that you first identified in your post. A few years ago I replaced the one on my ‘52 170B with one that I purchased from Air Repair using those part numbers.
Re: Tail U-Bolt
Posted: Thu Feb 15, 2024 11:20 pm
Yep …I mis-read your request…. sorry ‘bout that…. deleted the post.
Re: Tail U-Bolt
Posted: Fri Feb 16, 2024 12:21 am
by Joe Moilanen
Mine broke about 20 years ago and while I was starting to go down the rabbit hole to find one I used some aluminum flat bar, one on top and one on the bottom, drilled holes for two bolts to go one on each side. I think I remember doing some dressing out on the pieces to make them a fit perfect and work as good as a U-bolt. They did...and they are still on there...
Joe
4518C
Re: Tail U-Bolt
Posted: Fri Feb 16, 2024 4:19 am
by redacted
I got a replacement from air repair last year. No problem.
Re: Tail U-Bolt
Posted: Sun Oct 06, 2024 10:34 pm
by Rcondren
Do you have contact info for them?
Re: Tail U-Bolt
Posted: Mon Oct 07, 2024 3:20 am
by redacted
