High oil Temps
Posted: Sat Jun 18, 2005 2:53 pm
I was reading with interest another post about the finned oil filter devices. This is a different type of airplane but similar to the 170. My buddy’s 140A with an O-200 stc’d engine was running high oil temps. Close to read line, he was playing with trying to get the upper baffling as tight and as closed up as he could. Nothing seemed to make much difference. Then he had me fit a new nose bowl to his cowling because the old one was beat up. During the process I made a much tighter fit around his carburetor air filter, which would keep air from getting into the lower cowl area. I only did it for neatness and appearance. He was much surprised when the next time he flew the airplane he discovered that his oil temps were as much as 15 degrees cooler and no where read line. Now during the cooler parts of the year he has to run the block off plates in the lower cowl.
Jim
Jim
