Resource books still in storage, need info about rubber washers on both sides of firewall at motor mount through bolt.
Thanx,
motor mounts at firewall
1949 C170A
TIC170A #4747
1949 C170A
TIC170A #4747
John, one thing to be real careful about is there is a washer on the inside of the firewall that support the rubber --IT HAS A FLAT SIDE ON IT -- be sure that when replacing that you align the flat spot in the right place to keep from cutting the rivet on the support bracket. DON'T LEARN THE HARD WAY. I don't know how to answer your info question -What info? Ron
President 86-88
Re: motor mounts at firewall
My IP book says the bushings are 0550155 (4 required)JMACFLY wrote:Resource books still in storage, need info about rubber washers on both sides of firewall at motor mount through bolt.
Thanx,
The "pads" (smaller/rear bushings) are 0550154-2 (4 required)
Bela P. Havasreti
'54 C-180
'54 C-180
