Tailwheel size
Posted: Sun Nov 13, 2005 11:37 pm
by tshort
Don't have the airplane nearby to look...
A friend is building me a taildragger dragger (or similar contraption) in a welding class and needs to know the diameter of the C-170 tailwheel.
Anyone know offhand?
Thomas
Posted: Mon Nov 14, 2005 3:54 am
by cessna170bdriver
I'm not sure of exactly which measurement you need. In my hands I have a tape measure and a wheel with tire mounted. The wheel itself is 4 and 13/16 at it's largest diamter. Including the tire, it's 8 and 1/2 inches.
Hope this helps.
Posted: Mon Nov 14, 2005 4:27 am
by tshort
Perfect!
Posted: Mon Nov 14, 2005 6:32 pm
cessna170bdriver wrote:I'm not sure of exactly which measurement you need. In my hands I have a tape measure and a wheel with tire mounted. The wheel itself is 4 and 13/16 at it's largest diamter. Including the tire, it's 8 and 1/2 inches.
Hope this helps.
Put it in a 10" cube of cardboard and send it to me.
Posted: Mon Nov 14, 2005 7:25 pm
by cessna170bdriver
gahorn wrote:cessna170bdriver wrote:I'm not sure of exactly which measurement you need. In my hands I have a tape measure and a wheel with tire mounted. The wheel itself is 4 and 13/16 at it's largest diamter. Including the tire, it's 8 and 1/2 inches.
Hope this helps.
Wouldn't do ya much good George, unless you can find some oversize (OD) bearing races. The bores in the wheel halves are worn to the point that the races fall out.
That's why it's in my box-o-junk and not on the airplane.
Posted: Tue Nov 15, 2005 2:50 pm
by Dave Clark
I really shouldn't say this but if the fit is snug enough to keep it centered I'd JB weld new races in it and keep it for emergency use.
Posted: Wed Nov 16, 2005 5:30 pm
by zero.one.victor
Yeah, it'd sure be easier to just swap out tailwheels than to replace tire & tube out in the weeds somewhere. Wouldn't take up any more room than your spare t/w tire and tube -- you do carry one, don't you?-- or weigh a heck of a lot more either.
