electrical system voltage?
Posted: Mon Nov 28, 2005 8:10 pm
An A&P friend of mine was telling me that he had been having some electrical trouble with his 172, and traced it to having a too-low system voltage. It was around 12 point something with the engine running. He adjusted the "vibrator" type regulator to produce a reading of 13.5 or so volts, and that took care of the trouble.
I have a 60 amp alternator on my ragwing. My hard-wired GPS sez I'm only seeing around 12.4 volts. Although it's not giving me trouble, I thought I might readjust the regulator to get mid-13 volt readings. I opened up the regulator and lo & behold, it's all solid state! It's a Cessna p/n C611001-0201, made by Auxilec, Inc , mfr p/n VR600. It does have one solid state component inside there with an adjustment screw on it, but I thought I'd ask the forum about what I want to see for system voltages before I mess with it.
BTW, what brought this whole subject up with my friend,was that I had been having trouble lately with the starter turning the engine over very slowly. I charged the battery, checked the battery/starter connections, and checked the contacts in the starter switch (mounted on the starter)-- all OK. Turned out that 2 of the 4 brushes in the starter (the 2 you can't see very well with the starter still on the engine) were worn down to a nub! The other 2 looked great. I had a local auto-electric shop replace those 2 brushes for $15 (while I waited), now it spins 'er right over. So keep that in mind if your starting seems like it isn't up to snuff.
So what system voltage do I want to see?
