Wire Marking
Posted: Fri Dec 16, 2005 6:31 am
by n1410d
I am about to start re-wiring my 170A. I was wondering from those of you that have done this already, how did you lable your wires. I have seen wire stamping machines, but those are high dollar. Any ideas would be appreciated.
Patrick
N1410D
Grand Praire TX
Across from Joe down from Chuck.
Posted: Fri Dec 16, 2005 8:11 am
If you don't need the wire labelled all along the length,... you can label eac end with I.D. wrappers available at electronics stores. These are short, numbered "tapes" which are wrapped around the wire at each end. Pretty inexpensive, or ...you can easily make your own system. Indelible marker and use a system similar to resistors....a series of colored bands.
Black equals numeral "one", Blue equals numeral "two", etc etc. Black-Black--Blue-Black equals the number 1121.
Posted: Fri Dec 16, 2005 4:15 pm
by cessna170bdriver
Good idea George! That's an approach I've never thought of. Any combination of numbers/colors would work, but the "official" resistor color code is as follows:
0=Black
1=Brown
2=Red
3=Orange
4=Yellow
5=Green
6=Blue
7=Violet
8=Gray
9=White
In college (at the original UT!) we learned a little saying as a memory aid, but it can't be repeated here... :o
For trouble shooting later on, it might be a good idea to code the wires with the same numbers as they appear in the IPC. Just a thought.
Posted: Fri Dec 16, 2005 6:17 pm
Well,...I'd like to know the memory trick. PM me. :lol:
Wiring Code
Posted: Sat Dec 17, 2005 2:30 pm
by 170C
OK Miles, you have my curiosity going. PM me the UT saying.
Merry Christmas
Posted: Sat Dec 17, 2005 3:04 pm
Miles's ditty is interesting. Allen also sent me a similar one, along with an interesting theory about it's origination. (Allen- "I think this probably came from GI training in WW II for radio repairmen. I learned it from a Navy Chief when studying for my ham license as a youngster!")
A slightly altered version is:
Bad
Boys
Ravish
Our
Young
Girls
Behind
Victory
Garden
Walls.
Lets see now, are bad Boys Blue? Or Black? Or are their behinds Brown? (I can't recall which B is which color.) :roll:
wire markings
Posted: Sun Dec 18, 2005 4:20 am
by phantomphixer
Use an indelible razor point pen (Sharpie) and use white heat shrink. Then cover with a piece of clear heat shrink. Lasts forever. Used it in my "Flight Test" days with Douglas Aircraft for 20 years. Be careful pulling it thru holes or ty-wrap ties, if heat shrink is a little loose it'll pull off. :idea:
Posted: Tue Dec 20, 2005 12:38 am
by starkw1
Try these:
SA-ZIP Identification Cable Tie. 4 1/8" cable tie with attached "write on" ID window. We use these to ID misc coils of harnesses or wire.
$ .12 / Ea
http://www.steinair.com/cableties.htm
Warren
Mnemonics
Posted: Tue Dec 20, 2005 4:05 am
by jrenwick
The two mnemonics for "Black Brown Red Orange Yellow Green Blue Violet Gray White/Gold Silver [None]" in the Navy were:
Bad Boys R(avish) Our Young Girls
But Violet Gives Willingly...
Get Some Now.
and
Batman Blows Robin On Yonder Gotham Bridge...
Get Superman Next!
My $.02 worth
