Maule Tailwheel
Posted: Wed Apr 19, 2006 1:45 am
by echild
What is the chance of rebuilding a Maule tailwheel to a like new condition? There is play between the bronz bushing and the main shaft going towards the wheel. Also the bottom of the fork appears worn and the combination produces a fair amount of slop.
Does anyone have a good unti sitting around?
Everett
Posted: Wed Apr 19, 2006 3:59 am
Maule tailwheels and all their repair/overhaul parts are available from
Aircraft Spruce, 877-477-7823 . Online catalog at
http://www.aircraftspruce.com
Maule Tailwheel
Posted: Wed Apr 19, 2006 2:24 pm
by echild
George,
I first tried Spruce and they said the entire assembly have been on back order for awhile and maybe they will have some in a few days. I tried Wag Aero and they said it would be months before they got the assembly and Chief said the same and that Maule wouldn't even return their calls.
I finally got to Maule's parts and they saaid they should have a supply ion a few weeks. Rather than rebuild I would like to either get a new one or one that has been replaced and still is in good condition without the wear.
Everett
Another idea
Posted: Fri Apr 21, 2006 4:59 pm
by Romeo Tango
Everett, one thing you might consider is a Scott 3200 (or 3200A) replacement. I never liked the wheel-frame clearance of the Maule wheel, or the single support arm. The Scott wheel is much stronger, and with the 3200A version (same as used on the Husky) I'm a lot happier landing on soft/rough fields. More $ than repair or replace on the Maule, but I've not regretted that choice.
RT
p.s. the Scott 3200 is approved by the type Certificate, and Scott states that the 3200 and 3200A are identical for certificate purposes. Logbook entry and W&B change is it.
