Max Oil Pressure
Posted: Thu Jun 22, 2006 3:08 am
In a recent thread, Bruce stated:
Today I was reading thru TCM Form X30015 "Operators Manual", an FAA Approved document, and read on page 1, Specifications, that "Oil Pressure (cruising) (lbs/sq. in.)" is 30-60.
Just wanted to mention that now we've seen it in print from the mfr.
(This document can also be seen on the Member's Only Page of this website.)
I responded about a conversation I'd had with the TCM representative who anecdotally stated that oil pressure up to 60 psi is OK in the O-300 series engines. Someone else then mentioned that it'd have been nice if TCM had put that in writing. (Certainly a good comment.)N9149A wrote:...Also I just thought about oil pressure. Mine is running about 60psi. Just looked in the TCDS for the C-145 and it's the range is 30-40psi. Normally I'd not worry about this but I guess I'll make an adjustment there...
