High oil temperatures
Posted: Mon Jul 17, 2006 4:57 pm
I’m fighting a problem with high oil temperatures. I’ve read and done searches on the subject here but have come up short after trying all solutions using the stock setup.
Plane: 1951 170A with O-300A (TSMOH 670 hours) and Sensenich 74DR with 58 pitch (cruise).
Area: NW Colorado with a field elevation of 5240’ and much higher terrain if you want to get out of the basin.
Symptoms: Following repairs to a leaky exhaust system the engine oil continues to heat up to 225 in a very short time. One evening at about 78 degrees I shot one quick T&G then on the second round climbed to about 1400’ AGL at full throttle before she hit red line (1 person, 1/3 tanks). She stayed at 225 as I made a full power (about 2600 rpm) decent at about 120 mph indicated to about 200’ AGL on final.
After making additions to the baffling to hopefully force more air past the oil sump and other improvements I took her up when the temperature was about 70 degrees. I climbed at 85 to 90 mph to about 2250’ AGL before she hit 225 degrees. Oil temp didn't start backing down until I completely pulled power on short final. 1600 RPM decent held the oil temp steady.
Work so far: Replaced all exhaust flange gaskets and left side exhaust risers (major exhaust leak found on #2 and minor leak on #6). Removed and had the exhaust port faced on the #2 cylinder. Replaced intake gaskets, hoses, etc. on left side while I was at it. Muffler tape used on all exhaust clamps per George. Exhaust system pressure tested and passed the soap test.
Oil temp gauge checked before and after with the fryer thermometer in the dipstick hole method. Everything on the money.
Cylinders compression checked…all between 73.5 and 75. All cylinder temperatures and exhaust gas temperatures are in the normal range. Oil pressure maintains strong at about 50-55.
Baffling was in reasonably good condition. Improvements in baffling showed no apparent effect.
One blast tube to the oil filter adapter...the other to the generator via scat tube.
Engine runs smooth without any unusual noises. Filter was clean for metal particles 10 hours ago.
Timing is only slightly off by about 2 degrees…not enough to cause my problems.
Pulled the rockers on #2 and the pushrod tubes look clear without any sludge buildup.
Being at a lose…I.A. suggested putting in 2 quarts MMO in crank case and running it for 10 hours. I’m at about 3 hours with no notable improvement. I’m running 50 wt and know I can take it up to 240 degrees but am using a limit of 225 with the MMO addition. Before I put in the MMO the temps would still climb without signs of leveling off at 235 unless I backed her down to 2100 rpm or less in level or descending flight.
This is the first summer we’ve had this plane so there is no other points of reference on this machine.
I realize there are several modifications that can be done (legally of not) to treat the symptoms but I understand that shouldn’t be necessary if the engine is functioning properly. I would rather find and treat the problem instead of the symptoms.
Any suggestions??? I’m at a lose for where to go with it next.
Thanks in advance for any words of wisdom.
(Yes George…I’m in the process of becoming a full card carrying member of TIC170A.)
