Rewiring
Posted: Tue Jan 16, 2007 12:51 am
Hey all - have some time on my hands, so I am going to (under AP/AI supervision) rewire and replace fuses with circuitbreakers.
I had a few questions before I go to him so I am fully armed.
In checking the C170 parts manual, figure 23...
The master switch has two halves (confirmed looking under the panel). I had the original generator replaced with an alternator. I suspect one of the sides of the master switch is redundant, but I'm not sure. In a modern split-switch master one half is battery-ammeter/bus, and the other half is the field switch for the alternator. I know that my installation accomplishes this field switch with a dedicated circuitbreaker/switch.
The parts manual lists 23-6 as ""master switch to master solenoid" which is pretty straightforward. This would be connected to item 23-54 ("Master Switch to Ground") to close the circuit on the master solenoid and connect the battery to the bus.
Item 23-7 is "master switch to generator" and there is a figure to the right of that I cannot discern in my PDF (it looks like it might be "69" ("Voltage Control to Master Switch") which would make sense - acting as a control signal to enable the voltage regulator (similar to, but not the same as a field circuit for an alternator). If so, then I don't think this is required in this installation. I'd rather remove things not required, so going to a SPST switch is my choice.
Can anyone clear this up for me?
Thanks -
RT
Thanks -
RT
