Bolen conversion on C172
Posted: Tue Feb 27, 2007 7:35 pm
I've just recently acquired a 1956 C172 taildragger conversion done with the Bolen/Avcon STC. It was done over 15 years ago and has gone through several owners since. The logbooks are original and the proper sign offs, STC, 337's are documented, but there are no supporting documents or instructions for continued airworthiness. I know the gear legs are of Bolen's own design and manufacture. The only numbers I can find stamped on the legs are 000103L and 000103R. Would those be P/N or S/N. Also, anyone have any idea about the axles used in this conversion? Their design and structure don't match any C170/C180/C185 parts that I can find. The airplane has some serious toe-out issues documented by tire wear and handling quirks. The standard Cessna shims are considerably smaller that what is installed and of course don't have the large center hole for the "spindle" to fit through.
The current shims are drilled in such a way that you cannot restack or rotate them in anyway to adjust the toe-out to 0 or in somewhat. As everyone knows the current STC holder is non-responsive at best. In reading through the Forum I think I have identified maybe 4 members that may have a similar conversion. I would be more than happy to pay any copying cost and mailing charges if you have any more documentation on the installation of this mod, parts list, rigging instructions or maintenance procedures. The left wing was 9" lower than the right and we have gotten them within 3" of each other by putting shims under the main gear attach point under the floor. The Scott 3200 tailwheel came with compression springs and the slack chains. Brakes were the only method of steering during taxi. Changed them to tension springs and no slack and the taxiing is much improved. Did this conversion come originally with compression or tension spring setup?
Thanks in advance for any suggestions or comments.
All the best, Jim
All the best, Jim
