CO in the cockpit
CO in the cockpit
Because it is getting cold up here (Minnesota) I hooked up my heater to the muffler tube. I also tried my new AIM CO monitor. During taxi out I had all the alarms going off. During my short flight to pick up my instructor the monitor went to HI which is over 150 ppm. I opened the window and it went down to about 100.
My instructor did not want to fly in my plane.
My mechanic said that this is the same problem as before and many of the old planes have high CO. His solution "get rid of the monitor".
I removed the tube to the heater control valve on the firewall and duct taped up the intake opening. I flew the plane with low values of CO on the monitor ( 7 at cruise). I did see higher values during taxi (20) and takeoff (40) but they came down soon. My plane must be well sealed from the cold because the inside temp was at 58 while sitting in the sun.
(outside air was 27) In 3/4 hour of flying and testing it dropped only 5 degrees.
I took the plane to another FBO on the field I now hanger at. We took off the muffler from the left side (side for the heater) and found some leaks. They are sending it in for repair ($225 maybe) plus labor.
This time I should get the problem fixed for good.
Note to the group.
The spot CO monitor has never changed color. They are not good enough for checking for CO. Get an AIM monitor.
Tom Arsenault
N4163V
Note to the group.
Tom Arsenault
N4163V
Tom..... Checking for muffler leaks into the heater shroud is part of every annual on my 170. We remove the shroud, use a vacumn cleaner to blow air into the tail pipe and use soap and water to check for leaks.
I hope others check in on this post with how they deal with this issue.
With Winter coming on it is pretty important.
I wonder if they have Winter in Texas.
Bob
Bob
We have a phrase in Texas that goes: "The only thing between Amarillo and the Arctic is a barbed-wire fence!" There are days that is certainly true.flyer170 wrote:Tom..... Checking for muffler leaks into the heater shroud is part of every annual on my 170. We remove the shroud, use a vacumn cleaner to blow air into the tail pipe and use soap and water to check for leaks.
Bob
When taxiing, I usually get a strong smell of exhaust in the cabin. In flight, I do not smell it. I can see on the cowl where the exhaust follows the lower cowl lip around to the area where the gear legs enter the fuselage. I suspect this is where it is entering and will seal that better during the annual next week. Anyone have any other thoughts? I don't get the smell when using cabin heat (which is good because the entire exhaust system has about 60 hours on it).
Josh
CO Monitor
Tom,
Which model CO monitor do you have?
Is it hand held or mounted on the panel?
I recently had a CO 'encounter' flying (taxiing actually) a Grumman Tiger AA5 (yes, I will fly anything I can get my hand on). On closing the sliding canopy there was a strong exhaust smell. The 'yellow spot' CO monitor had gone black. Needless to say I taxied back to the hangar to have it looked at. Subsequent inspection found a large crack in the exhaust mainfold. Cabin heat was not in use but a lot of exhaust gas found its way into the cockpit.
David.
David.
[quote="flyer170"]Tom..... Checking for muffler leaks into the heater shroud is part of every annual on my 170. We remove the shroud, use a vacumn cleaner to blow air into the tail pipe and use soap and water to check for leaks.
Bob[/quote]
I don't know about anything west of Crockett, TX but we don't allow winter here in Lousiana!
Leaks in any part of the exhaust system can be fatal on long flights. Carbon monoxide is called the silent killer! Very small quantities in the cabin air is capable of impairing abilities required for management of inflight situations.
Another thing to remember, CARBON MONOXIDE CAN BE ODORLESS! - - FIND IT OUT AND THEN GET IT OUT!
Bob[/quote]
CO in the cockpit
Here is some more info on the subject. I had the muffler removed and sent in for repair. Welding is going to cost $375 plus shipping. I think the total cost is going to be around $700.
The muffler looks good. Mostly replacement. Here are some figures from my AIM monitor which is a hand held that I tie to the ash tray.
Before fix Cruise with heat on Over 150 ppm (highest reading)
After fix Cruise with heat on 8 to 10 ppm
This is about the same as with the heater hose off and the firewall intake taped up. (5 to 7 ppm)
Other figures about the same before (heat off) and after the fix.
Taxi 8 to 17 ppm
Runup 44 to 51 ppm
T/O 55 down to 47 ppm
Climb 34 ppm
Cruise 10 down to 8 ppm
Landing 16 ppm
Taxi in 25 ppm
I would like to reduce the remaining amounts but do not have to.
Tom Arsenault
N4163V
Taxi 8 to 17 ppm
Runup 44 to 51 ppm
Climb 34 ppm
Landing 16 ppm
Taxi in 25 ppm
Tom Arsenault
N4163V
CO in the cockpit
Here is some more info that I have found.
How much is dangerous?
High concentrations of carbon monoxide kill in less than five minutes. At low concentrations it will require a longer period of time to affect the body. Exceeding the EPA concentration of 9 ppm for more than 8 hours is suspected to produce adverse health affects in persons at risk. The U.S. Occupational Health and Safety limit for healthy workers is 50 ppm. Carbon monoxide detectors, which are designed to protect against high concentration of carbon monoxide are required to sound an alarm when concentrations are greater than 100 ppm. Continued exposure to carbon monoxide can cause permanent brain, nerve, or heart damage. Some people require years to recover while others might never fully recover.
Tom Arsenault
N4163V
Tom Arsenault
N4163V
Tom,does your ragwing still have the pancake mufflers? "The muffler looks good.mostly replacement." Could you elaborate a little? Who did the repair work? Most exhaust outfits just about hang up on you when you mention pancake mufflers,or else try to sell you a set of Hanlon-Wilson's for $1500. My pancakes are airworthy,now,but have had a lot of weld repairs thru the years. It'd be nice to have them rejuvenated,next time they spring a leak.
Answers to some of the questions.
I have an O 300 A engine that has Hanlon-Wilson mufflers. I only had the muffler for the heater (sans baffle) sent in for repair. The repair shop is in Burnsville MN (suburb of MPS). I will have an exact address after I pay the bill (today) and have my log books updated.
The meter is an AIM model 935 and I think the cost is about $70 plus shipping. It is a self contained an should run for 3 years and then tossed. The company is
IST Aim Corporation
1624 Headway Circle
Austin Tx 78754
Tech Support
1 888 391 7258
More on CO
http://www.carbonmonoxide.org
IST Aim Corporation
1624 Headway Circle
Austin Tx 78754
Tech Support
1 888 391 7258
More on CO
Carbon Monoxide in the cockpit
Another item from Tom Arsenault
I still wonder if this (CO in the cabin even with the heater shut) and high altitude for 2 days did not have some bearing on my going off the runway at Durango. I had some feeling that when I started to leave the runway that I did nothing. It wasn't until I saw the fence coming close that I decided that I had to get out of there. I should have stopped the plane in the brush rather than try to get back on the runway with that big drop from the runway.
Read about the "incident/accident" at:
http://www.winternet.com/~taa/TomsTripToAccidentP1.html
Tom Arsenault
N4163V
Tom Arsenault
N4163V
