Scott Tailwheel bushing
Posted: Wed Jan 30, 2008 6:03 pm
by jlwild
Ok folks, where can I purchase the bushing (Fig. 94-3) that is used to connect the Scott tailwheel bracket to the tailwheel spring :?: Mine is worn and needs to be replaced.
In the IPC (Fig. 94-3) it is clearly shown and has a part no. of 0442011-2. I have tried Aircraft Spruce and other parts catalogs, but no luck. Before calling Cessna Parts, thought I would ask the forum experts if they have have any better suggestions 8)
Jim
Posted: Wed Jan 30, 2008 6:20 pm
by N2255D
http://cessnaparts.com/parts.cfm says part in stock for $10.19 ea
http://www.parts123.com/cessna-parts/default.htm also says part in stock and $10.19 ea
I've used them both and never had a problem. Unfortunately they both have a minimum order of $25. Maybe the local Cessna dealer could order it without a minimum and not too much more expensive.
Posted: Thu Jan 31, 2008 2:03 am
by robert.p.bowen
...or call Air Repair. 662-846-0228. Last time I was there they had a crate full of them.
Posted: Thu Jan 31, 2008 2:27 am
by jlwild
Thanks Walt and Bob,
I knew someone would point me in the right direction. I will give both Air Repair and Cessna Parts a call. Then take the lowest price. 8)
Jim
Posted: Thu Jan 31, 2008 6:17 am
by ak2711c
Alaska Bushwheel also sells them. I think the last time I ordered one from them they were only $5 or $6.
Shawn
Bushing
Posted: Thu Jan 31, 2008 5:10 pm
by Dennis
Hi Jim, Cessna wants $10.16 let your cessna dealer know your a TIC Member and ask for a discount and it may be less. I always start my search with cessna that way I know availability and price. Once I know what cessna wants for a part I make sure other sources aren't gouging me.
Posted: Fri Feb 01, 2008 2:40 am
by jlwild
To All,
Air Repair took my order and let me have the TIC 170 discount. It turns out the cost of mailing is more expensive the the $10.00 part.
Thanks again for all the input.
Jim
