180 Gear
Re: 180 Gear
Just curious...why? Unless you're planning on operating from rough strips, I'm not sure what the advantage is. The stock gear on my 52 B model has served me well for many years...Russ Farris
All glory is fleeting...
Re: 180 Gear
tailpilot, ... check/search for discussions on this board about such mods. There are pros and cons.
(And you should be a 170 Assn member if you wish to advertise.)
Re: 180 Gear
If it were me I would have them stripped of all paint, magnafluxed to check for cracks, bead blasted, and then annealed. I would also assemble them with new bolts for the axles.
