Engine mount to Firewall bolt torque for N1320D
Posted: Sun Dec 01, 2002 8:04 pm
by Psmith
I have a 51 170A. What is the criteria for replacing the rubber pads (engine mount to firewall) and what is the bolt torque. Also there are 2 slotted tabs on copilots side, cabin side of the firewall, what are/were they for? Thanks.
Pete Smith N1320D
Lewistown, MT
Posted: Mon Dec 02, 2002 4:37 am
by n3439d
The cessna 172 manuals cover this subject well, the mounts and torque values are listed.
ken
Re: Engine mount to Firewall bolt torque for N1320D
Posted: Mon Dec 02, 2002 4:22 pm
Psmith wrote:I have a 51 170A. What is the criteria for replacing the rubber pads (engine mount to firewall) and what is the bolt torque. Also there are 2 slotted tabs on copilots side, cabin side of the firewall, what are/were they for? Thanks.
Pete Smith N1320D
Lewistown, MT
The "Cessna 100 Series, 1962 and prior, Service Manual" (available from Aircraft Spruce 877/477-7823) says to tighten the mounts until the rubber mounts "bulge out slightly". The mounts should be replaced whenever they are dry rotted, cracked, sag excessively or are excessively age-hardened.
Some mounts (not usually found on 170's) have a steel bushing within the mount itself, and those should be torqued according to the torque tables found on page 1-8 in the service manual.
51 170A Rubber engine mounts
Posted: Wed Dec 04, 2002 12:57 am
by Psmith
Are the rubber firewall mount pads typically replaced before the plane is 52 years old?
Pete
Re: 51 170A Rubber engine mounts
Posted: Wed Dec 04, 2002 3:42 am
by mit
Psmith wrote:Are the rubber firewall mount pads typically replaced before the plane is 52 years old?
Pete
Probably. 48's don't have any except at the eng. to mount.
Posted: Wed Dec 04, 2002 8:10 am
by N170BP
Mine were trashed, and I suspect they were the originals.
I was looking for a torque value as well but only found
the blurb in the 100 series service manual saying to tighten
them until they bulge slightly. I suppose over-tightening
them could lead to cracking / failure....
The bushings were relatively inexpensive (got them
from
http://www.iwantcessnaparts.com).
Bela P. Havasreti
'54 C-170B N170BP
